Liked 5 Times in 4 Posts
Are we allowed a 1.6 rocker where a 1.5 is listed to make our camshaft lift legal? Thanks for your help.
Liked 1,927 Times in 433 Posts
Absolutely not in Stock Eliminator.
Alan Roehrich 212A G/S |
Liked 346 Times in 126 Posts
Get the rulebook, it has what we can and cannot do to the eingines
David,
I read the rule book where does it say what rocker ratio? |
Rocker ratio is in the blueprint specifications. You absolutely cannot have a rocker ratio higher than that specified in the guide for your engine.
Thanks Alan, I had a conversation last evening and the fellow seemed to think the rule had changed.
Liked 54 Times in 18 Posts
Get a cam made that meets the lift spec with the stock rockers
Liked 3 Times in 1 Post
PJ, I heard the rocker ratio was dropped too. I called Travis and he said it was still in full effect. He was the one who checked them at the Allstars this year. Lift at valve as well as ratio will be enforced.
Wade O |
Liked 325 Times in 50 Posts
If your rocker has no number (ratio) stamped on it, don't worry about it. I was thrown out because mine were stamped 1.65 and the rules said 1.60. The cam checked ok. Without the numbers nobody knows or cares I think.
Jeff Teuton 4022 STK |
