Old 12-07-2013, 10:20 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default GM 12-bolt U-bolts
Anyone have a reliable link/source for U-bolts for a Chevy 12-bolt housing? I'm in need of 8' to 9" length due to the use of lowering blocks.
Rich Taylor
I/SA - 321
Old 12-07-2013, 10:37 AM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: GM 12-bolt U-bolts
Go to your local spring repair shop, they can make them any length you need.
Bob Pagano A/SA
Old 12-07-2013, 10:54 AM   #3
HandOverFist
If I understand correctly Chevy uses a 3-1/16" inside dimension?
Rich Taylor
I/SA - 321
Old 12-07-2013, 01:22 PM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
Just had a local spring shop do these for a Nova mono leaf 12 bolt:
3 1/8" inside-to-inside and 7 1/4" leg length (measured from the outside top of the 'u'). When installed, there is 2" of thread below the Cal Trac mounting plates.
Not the exact info you asked for, but might give you some reference for length.... -Al
P.S. I like the Camaro build pics.
"That'll never work....."
Old 12-07-2013, 06:25 PM   #5
Barry Polley
Guest
Posts: n/a
My local parts store had them in stock.
Old 12-07-2013, 09:43 PM   #6
HandOverFist
Yeah, I need at least 8" because of the 1" lowering blocks on our car. I don't know of anyone local in my parts.
Rich Taylor
I/SA - 321
Old 12-08-2013, 07:00 AM   #7
Alan Nyhus
Rich, Jegs has these 9.5" u-bolts on hand:
http://www.jegs.com/i/AFCO/921/20238-9/10002/-1
Hope this helps. -Al
Old 12-08-2013, 10:32 AM   #8
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
I picked up a set at napa in the 4x4 stuff...had to buy a kit w/lowering/raising blocks but they look cool hanging on my wall
Old 12-08-2013, 12:20 PM   #9
Run to Rund
Liked 54 Times in 27 Posts
I got some u-bolts here:
http://www.autoandtrucksprings.com/
Old 12-08-2013, 12:38 PM   #10
HandOverFist
Perfect Alan - I was looking at a set there earlier but they would not have them until the 18th. Don't know why these didnt show up in the search.
Edit: Just found the same ones on the Summit site as well... http://www.summitracing.com/search/p...0Leaf%20Spring
Rich Taylor
I/SA - 321
