Old 09-16-2013, 08:52 AM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Intermittent no start condition
I have an intermittent no start condition on my 98 Pontiac Stocker, 350 with Accell Calmap ECU. Randomly, the car will crank but not start. It might start 10 times in a row then the 11th. time ....crank, no start. Let it sit for a few minutes(5-10)...and it fires right up.
Recently, had a battery go bad....replaced it. The only other change was to the fuel. At Martin, had to switch to Sunoco as VP was not available.
Because it is intermittent, I have not been able to determine if this condition is fuel or ignition related. It has an MSD Digital 7.
Happened yesterday in the staging lanes at a test /tune.....waited about 5 minutes and it fired right up.
Anyone experience anything like this?
Thanks.
John Nechiporchik is offline   Reply With Quote
Old 09-16-2013, 12:33 PM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Intermittent no start condition
Dave Noll, EF/S ,?/SA 6526
Old 09-16-2013, 01:52 PM   #3
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Get a spark tester to verify that you have fire. If no fire, suspect optispark or ignition module on coil. If fire is present and it won't start, try pouring a little gas into the intake through the throttle body opening. If it starts when pouring gas (not the same gas that you recently changed to), it will be a fuel problem. It could possibly be bad injectors, or it could be fuel contamination. Just a few ideas.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 09-16-2013, 02:49 PM   #4
John Nechiporchik
Thanks for the ideas. What fails on the optispark? I've seen references to this before as a problem area.
Thanks
Old 09-16-2013, 04:14 PM   #5
Steve Williams
Thanks
The optical sensor gets knocked out usually by a foreign substance. Oil, water. A quick continuity check of the harness should be done. Manipulate the wires as you do this. They can and do go bad as well.
Steve Williams is offline   Reply With Quote
Old 09-16-2013, 05:45 PM   #6
John Nechiporchik
This thing has an MSD Distributor Cap,coil (HVC2) and crank trigger.
Old 09-16-2013, 05:59 PM   #7
Dave Noll
Dave Noll's Avatar
Old 09-16-2013, 06:26 PM   #8
FED 387
Liked 333 Times in 180 Posts
Try a different coil---this typical of a MSD 8261 coil ---they cannot take a continous start and stop round after round like this without overheating and doing exactly what you are describing--- been there done that--- problem should be solved---FED387
Old 09-16-2013, 08:15 PM   #9
John Nechiporchik
Started it tonight....fired right up. Ran for a minute.....shut off.....tried again 5 times over the next 3 hours....no start.
FED....would you recommend another P/N coil or get another 8261?
Also, I recall previously that the fuel regulator seemed to stay near operating pressure for quite some time after the pump/engine was shut down. This regulator (Paxton) is immediately bleeding off instantly after the pump is shut off (engine NOT running) Drops to 15 psi (set at 45) in about 3 minutes.
Wondering if this is the problem?
Old 09-16-2013, 08:52 PM   #10
FED 387
try any other coil other than another a MSD 8261 if you are going to run more than a lap every hour or two just to see if that is the problem--- for repeat operation much like stock/super stock/ bracket cars go DO NOT USE the MSD 8261 it will usually do what you are describing---an MSD 8251 will not cause the symptoms you are describing---an MSD8261 coil gets so hot internally with repeat operation it breaks down due to the heat--- if you ran the car for a lap then shut it down for a while say 30 +minutes then ran another lap you MIGHT be OK but the MSD 8261 coil is not designed for lap after lap
