Old 08-24-2014, 01:34 AM   #1
SSGT Mustang
Liked 204 Times in 54 Posts
Default Fuel Check Valves
Can someone please refresh my memory: Do fuel check valves have to be in the engine bay, and run off of the regular? Or can they be in the back of the car, and run from the fuel cell outlet?
I would prefer to relocate it to the back of the car if possible, but I don't think that it's legal (or it didn't used to be)..
Thanks.
SSGT Mustang is offline   Reply With Quote
Old 08-24-2014, 02:14 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Fuel Check Valves
It just reads between the fuel tank and the carb for Stock and Super Stock. It's back in the General section.
Dale
Dale Shearon
68 Mustang 6394
Old 08-24-2014, 08:55 AM   #3
Rsmith38
Liked 28 Times in 15 Posts
I have mine under the back of the Comanche; but most cars aren't high enough to get under the back!
Rsmith38 is offline   Reply With Quote
Old 08-24-2014, 10:02 AM   #4
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Most fuel check valves are mounted under hood on fuel pressure regulator outlet port. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 08-24-2014, 10:30 AM   #5
FireSale
FireSale's Avatar
Mine's at the fuel pump which is just below trunk floor level at the fuel cell. It's a 68 Mustang, so it's a short reach. One of those push button dribble deals.
Dale
Dale Shearon
68 Mustang 6394
Old 08-24-2014, 11:23 AM   #6
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Mine was in the back, I was told to put it under the hood.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 08-24-2014, 11:32 AM   #7
SSGT Mustang
Thanks. I've got a modified car that I'm putting back in service. The valve is in the engine bay, but I have a glass hood. I have to turn a bunch of zsus fasteners and put the hood on the ground every time I have to do a fuel check . It's a PIA.
I would have liked to use the second port on the fuel cell to run the valve, and mount it on the inside of the bumper out of sight. You'd think that that'd be fine, since that's where your fuel comes from, or is supposed to come from. Nevertheless, I figured tech would have an issue with the idea.
Thanks everyone for your replies.
Old 08-24-2014, 05:41 PM   #8
Alan Nyhus
Liked 799 Times in 236 Posts
From the 2014 NHRA rule book, Section 20 General Regulations 1.5 Fuel Systems:
"All cars in Stock, Super Stock, Competition and Pro Stock must be equipped with a positive-lock drain valve located between the fuel tank and the carburetor(s) or fuel injectors to facilitate removal of fuel samples for fuel-check purposes."
"That'll never work....."
Old 08-24-2014, 07:10 PM   #9
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
The cost of running a Stocker is going up..............
So now I need a hidden second fuel cell, fuel pump, 3 way valve and Q16 VP fuel so that I can be competitive....
When will it end, when will it end...
Bob Mulry 7516 STK
A & M Motorsports
