Old 11-19-2019, 09:22 PM   #1
Ernie Neal
Ernie Neal's Avatar
Liked 326 Times in 78 Posts
Default 1996 B Body Caprice for Superstock
Guys, I was really busy during this process. I did get some photos occasionally. I will try and post some from time to time. I was lucky to make it to Indy with this car. Lot of hours for a 70 years old. I had some help along the way. Glenn Betz, my sons David and Ernie II. Rick Stanghetti came over from Cincinnati. Gary Powers from North Carolina was here for family and helped me some too. Ryan Betz helped some when he came out to his Uncle Glenn's. Jay Koelling came down from Indy and participated in some disassembly and cleaning.
My son normally welds up the rear ends, but due to the time line, I bought the bolt in Moser housing, axles and brakes.
My racing pal out of Louisville, Larry Wilson, loaned me the Chevelle headers so I didn't have to make them myself.
This Caprice came out of North Carolina, and is a rust free, 237k miles on the original 265.
David Tincher, waterjet cut necessary pieces to get the Caprice going. I generate a dwg file and he gets it cut out.
Ernie Neal
SS 354
ID:	52615   Click image for larger version
Name:	moser housing B body.jpg
ID:	52616   Click image for larger version
ID:	52618   Click image for larger version
Name:	under dash stock.jpg
ID:	52619   Click image for larger version
Name:	more fitting.jpg
ID:	52621   Click image for larger version
Name:	white spacers.jpg
Old 11-21-2019, 08:44 AM   #2
Ernie Neal
Ernie Neal's Avatar
Default Re: 1996 B Body Caprice for Superstock
Since I have never raced one of these bodies, I didn't know if any of that rear suspension would give up. I took the liberty to making some reinforcement before I broke it. I knew my engine produced smaller amount of torque with a 3" stroke, so I wasn't that concerned about ripping it out.
I used brake kit for an 82-92 Camaro and made the mount bracket to meet the dust shield mounting holes. I enlarged them to 3/8". Of course had to cut off the stock mounting as well.
Brake pedal mount modification was needed to achieve the recommended brake pedal ratio and rod alignment. I went ahead and incorporated the master cylinder mount, for ease of replacement.
Ernie Neal
SS 354
Oh sorry these pictures are not in chronological order
Name:	lower arm supported.jpg
ID:	52628   Click image for larger version
Name:	master cylinder mount.jpg
ID:	52629   Click image for larger version
Name:	my caliper mnt bracket.jpg
Name:	my caliper mount bracket.jpg
ID:	52631   Click image for larger version
Name:	pedal  ratio modification.jpg
ID:	52632   Click image for larger version
Name:	right upper supported.jpg
ID:	52634   Click image for larger version
Name:	ride stock.jpg
ID:	52635   Click image for larger version
Name:	upper rear supported.jpg
Old 11-27-2019, 10:05 PM   #3
Ernie Neal
Ernie Neal's Avatar
plated the lower A frame mount after cutting out the factory crossmember for oil pan clearance
some rollbar fab work
cleaning and wire brushing the frame while it was dropped down.
the bottom of this car is really nice for a 96
Happy Thanksgiving to all
Ernie Neal
SS 354
ID:	52647   Click image for larger version
ID:	52648   Click image for larger version
Name:	pan clear right.jpg
ID:	52650   Click image for larger version
Name:	right rear bar.jpg
ID:	52651   Click image for larger version
Name:	rollbar support hole.jpg
Name:	start of frame clean.jpg
ID:	52653   Click image for larger version
Name:	painted some of bar now.jpg
ID:	52654   Click image for larger version
Old 11-30-2019, 08:42 PM   #4
Ernie Neal
Ernie Neal's Avatar
Had to get a little creative with the cherry picker and a roll-around cart to support the body while we were cleaning, rollbar installing and painting the frame.
Hope you can make it out via the pictures
Ernie II and I worked with grinders and cup brushes to get the frame ready for some paint.
I got to tell you guys, while we were both using those cup brushes, my son went out to get in his truck, when he got in he yelled out. He came back into the garage to find out ole' dad had stuck with one of the wires, ouch. I laughed, but he didn't think it was to funny.
Still more to come
Ernie Neal
SS 354
Name:	body suspended 2.jpg
ID:	52663   Click image for larger version
Name:	body suspended.jpg
ID:	52664   Click image for larger version
Name:	cherry picker suspension.jpg
Name:	Ern II helping on frame.jpg
ID:	52666   Click image for larger version
Name:	Ern II still at it.jpg
ID:	52667   Click image for larger version
Name:	frame clean underway.jpg
ID:	52669   Click image for larger version
ID:	52670   Click image for larger version
Old 12-01-2019, 09:17 AM   #5
Liked 10,681 Times in 2,222 Posts
What you need show is how much dirt and dust comes off of the car and how it goes everywhere. Very nice work by all.
Old 12-06-2019, 09:16 PM   #6
Ernie Neal
Ernie Neal's Avatar
Larry,
I think I swept up about three dust pans full. Everything in the shop covered. I think I am still blowing it out of my nose.
More bottom photos
Rollbar work along with front crossmember cut out for oil pan clearance and plating area where metal was removed.
Ernie
SS 354
ID:	52683   Click image for larger version
Name:	bar right.jpg
ID:	52684   Click image for larger version
Name:	bar to frame.jpg
ID:	52686   Click image for larger version
ID:	52687   Click image for larger version
Name:	pan clearance.jpg
ID:	52689   Click image for larger version
Name:	right frame.jpg
Old 12-07-2019, 11:45 AM   #7
Ernie Neal
Ernie Neal's Avatar
My son (Ernie II) is working on a startup video and pictures, I will post it too
Work on the left front caliper mount
Spohn upper arms on the back
Brake line plumbing
Didn't have a pitman arm puller, but this bearing puller worked.
I added these bars to strengthen what I had cut out and reinforced for oil pan. I didn't want any frame flex. The lower bars are 1 5/8" chrome moly and 1 1/4" on X and top. I didn't want to motorplate to be overloaded.
Stay tuned
Ernie Neal
SS 354
Planning PRI next Thursday, hope to see some of you there
Name:	92 Camaro brakes.jpg
ID:	52691   Click image for larger version
Name:	left spohn arm.jpg
ID:	52692   Click image for larger version
Name:	left spohn arm2.jpg
Name:	oil pan clearance mnt support.jpg
ID:	52694   Click image for larger version
Name:	oil pan clearance mount support.jpg
ID:	52695   Click image for larger version
Name:	pitman arm coming off.jpg
Name:	rear end installed.jpg
ID:	52697   Click image for larger version
Name:	right sphon arm.jpg
Old 12-15-2019, 12:30 PM   #8
Ernie Neal
Ernie Neal's Avatar
Just a few more
Photos of driveshaft and loop in place. The crossmember installed. Engine just hanging there with straps. Riner transmission installed.
Engine bay photos
Ernie Neal
SS 354
ID:	52726   Click image for larger version
ID:	52727   Click image for larger version
Name:	engine and trans mounted.jpg
Name:	engine clearance check.jpg
ID:	52729   Click image for larger version
Name:	engine compartment.jpg
ID:	52730   Click image for larger version
ID:	52732   Click image for larger version
Name:	riner transmission installed.jpg
Old 12-15-2019, 12:58 PM   #9
Ernie Neal
Ernie Neal's Avatar
photos of engine bay, Larry Wilson's Chevelle headers, oil pan clearance and front engine motorplate mounting bracket
Ernie Neal
SS 354
Name:	Chevelle headers fit.jpg
ID:	52734   Click image for larger version
Name:	engine bay later.jpg
ID:	52735   Click image for larger version
Name:	oil pan clearance cross-braced.jpg
ID:	52737   Click image for larger version
Name:	oil pan clearance cross-bracing.jpg
ID:	52738   Click image for larger version
Name:	pan clearance support.jpg
Name:	right engine mount.jpg
Old 12-15-2019, 01:05 PM   #10
Ernie Neal
Ernie Neal's Avatar
photos of driveshaft loop and crossmember, plus underside of car
Ernie Neal
SS 354
Name:	driveshaft loop heavy.jpg
ID:	52741   Click image for larger version
Name:	driveshaft loop installed.jpg
ID:	52742   Click image for larger version
ID:	52744   Click image for larger version
Name:	ds loop installed.jpg
ID:	52745   Click image for larger version
Name:	moly crossmember.jpg
Name:	moly xmember.jpg
ID:	52747   Click image for larger version
