Old 07-06-2013, 08:08 PM   #1
brent flynn
brent flynn's Avatar
Default Smith Machine Ceramic llifters...
Well, after waiting for nearly 2 months, cant get SMith Machine(Schubeck style) lifters for my Pontiac... I guess they are having problems getting them done, by whoever is doing them. So , i guess im gonna go with a regular steel lifter...ANy suggestions? For E or F/SA 400/330HP Pontiac....
Old 07-06-2013, 08:15 PM   #2
Liked 1,811 Times in 412 Posts
Default Re: Smith Machine Ceramic llifters...
Trend Tool Steel. They do have a limited travel model that passes NHRA tech for a hydraulic lifter in Stock.
I suggest at least a P55 lobe lock cast iron core, and nitriding.
Old 07-06-2013, 09:11 PM   #3
brent flynn
Will check into them... Probably cant put them on a used cam?
Old 07-06-2013, 09:23 PM   #4
blueboatcar
Liked 11 Times in 1 Post
Cliff Sherman tool steel limited travel as well
blueboatcar is offline   Reply With Quote
Old 07-06-2013, 09:56 PM   #5
Tom Moock
Liked 10 Times in 6 Posts
Brent, I was told with a new cam, You break in cam with smith or schubeck lifter, then change to tool steel lifter, I think you would be ok on used cam, but i don't build my motors. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 07-07-2013, 02:28 AM   #6
Bill Edgeworth
To my knowledge Trend does not make a Pontiac lifter. Pontiac lifters are the same diameter as a Chevy but Pontiac ones are taller. Putting a Chevy lifter in a Pontiac can cause the oil gallery to become exposed at the top of the lifter when the lifter is on the base circle and or the lifter oil groove to become exposed on the bottom side. I can’t remember which it is, it’s been a few years since I decided to see if Chevy ones would fit. I would just use the Sherman lifters. If you really want to use ceramics I have a used set. I quit using ceramics years ago.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 07-07-2013, 09:12 AM   #7
brent flynn
Hey Bill, in your opinion, is there much ET between the 2? Im planning on being in the 6500 rpm range...What about spring pressures? I might be interested in the used Ceramics...let me know what you need for them, and if they need resurfaced.... Thanks, BRent
Old 07-07-2013, 04:52 PM   #8
Jeff Lee
Jeff Lee's Avatar
Guys, if something is not in a catalog, pick up the phone and ask. It's not that difficult! PPP just made me a set of AMC TS lifters and there were none in the catalog. I just sent them a lifter I wanted copied and in less than 4 weeks had a set. Didn't cost extra either. Now it's available for everybody.
If I sat around looking at catalogs for availability while building an AMC, I'd never get it done.
Jeff Lee 7494 D/S '70 AMX
Old 07-07-2013, 08:02 PM   #9
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Smith Machine Ceramic llifters...
Brent, you are so lucky you did not get those sm lifters. Jeff is right about PPP listers. Sm lifters destroy engines! Sad but true. Until they improve quality control, tool steel is the way to go.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 07-08-2013, 01:19 PM   #10
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Hey Brent X 2 on the Shermans have well over 100 passes on mine no issues !!!
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
