Liked 1,805 Times in 423 Posts
Trying to put rear disc brakes on my nova .12 bolt rear with Moser axels.Disc brake kit is Strange...Notice this kit is for Strange axels .They must make another bracket or do I have to use there axels or c clip eliminator kit? Asking if anyone has run into this problem.I figure Strange is closed till next week. .Please help wanna race this weekend
james perrone 1290 STK |
Liked 20 Times in 9 Posts
Is it the bracket to small for the axle flange.
James, is the issue that caliper is not centering up with the rotor?
The axle standout (distance from the rear end housing end to axle flange) may be different between the Strange and Moser axles, possibly causing misalignment. |
James call me when you can......I just went through the same thing on my 12 bolt with moser axles using moser C clip eliminators.........Your C clip eliminator is over in 1/8 to thick for strange brake assembly ......Call me and ill tell you how I fixed it
Ty Casey 817-709-5868 |
tylerx you hit the nail on the head I will call
Liked 9 Times in 3 Posts
james if you can't get ahold of tyler. all you need to do is have the aluminum brg. mount of the c clip eliminator machined down the thickness of the caliper mount, on the inner side.
Mark Markow 171 ss/tb |
Thank you Mr Markow
