Old 06-26-2013, 12:41 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default SW Anti Roll bar for camaros and firebirds
A while back there was a article in a magizine about the SW anti roll bar for the back of 3rd and 4th gen camaros and firebirds. It was being installed on a stock eliminator car. That started a discussion here about was it legal or not when installed as S&W intended it to be installed. My question is this. Is it still Illegal to weld it in or is NHRA now allowing it? I cant find the thread for some reason to see what happend as the conversation went on.
Can Heim joints be used in swaybar/anti roll bar end links instead of the tradional bolt and bushing setup if I decide to go that way instead of with the S&W setup?
Thanks
Rob
Old 06-26-2013, 03:02 PM   #2
Billy Nees
Liked 7,734 Times in 1,739 Posts
Default Re: SW Anti Roll bar for camaros and firebirds
I've always been under the impression that if it can't be bolted in then it isn't legal.
Billy Nees 1188 STK, SS
Old 06-27-2013, 12:30 PM   #3
Tim Lisson
No welding is my understanding as well.
Spohn Performance has a BOLT-in that works very well.
Tim
Tim Lisson is offline   Reply With Quote
Old 06-27-2013, 08:55 PM   #4
Rob Petrie E395
Tim
That's what I am going with as I have one here that was on my bracket car before I switched it to the S&W one. Just like the SW one cause its all tucked up out of the way but if its not legal its not for me.
Thanks guys
Rob
Old 06-27-2013, 09:25 PM   #5
Doug Blackley
Doug Blackley's Avatar
As I recall in that original thread, a number of NHRA's divisional tech directors expressed that they would not pass that set up. Now that said, the o.e. bar can be used effectively.
Doug Blackley 1697 STK
Old 06-28-2013, 02:12 PM   #6
mannymen
Liked 13 Times in 7 Posts
Are the HRpartsNstuff rear bolt on sway bars legal in Stock E? Also, is it correct that GM A-Body aftermarket rear control arms are legal if the bottom bar is NON-Adjustable where the top control arm can be adjustable? Paul from HRparts has mentioned that they were NHRA Stock E legal as long as they bolt in only. No welding. Anyone using one?
See link below for an example
http://www.hrpartsandstuff.com/
N/A
mannymen is offline   Reply With Quote
Old 06-28-2013, 04:16 PM   #7
Jody Noble
I use one on a 65 chevelle (hr partsnstuff) works very well, nice piece and completely bolt on.
Jody Noble is offline   Reply With Quote
Old 06-28-2013, 06:07 PM   #8
Signman
Liked 269 Times in 99 Posts
There were some questions about the S&W roll bar a while back. Should contact them directly on how it was handled
All the bolt on sway bars are great but you really don't need it on a 3rd Gen. Camaro unless you wish to use it as a tuning aid. Which really is a band-aid approach, use air bags and weight.
Depending on which way you want to go there are several bolt on systems, they all work and you can do it yourself with some investigation and labor. If you want to run a sway bar the thinnest stock bar will work.
As Alf Wiebe said to me when doing my research: "The stock stuff isn't that bad."
