Old 03-17-2013, 09:02 PM   #1
randall502
Default how to speed up my pure stock 305 Camaro
I have a 1991 Camaro Rs 305ci with throttle body injection. I have installed a torque converter and removed a/c and smog pump and have drag radials. I want to be able to drive this car to the track and race it. Any suggestions I can do besides the obvious? - spending tons of $
randall502 is offline   Reply With Quote
Old 03-17-2013, 09:22 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: how to speed up my pure stock 305 Camaro
Colder thermostat, lower temp fan switch, and a computer chip!
Ed Wright 4156 SS/JA
Old 03-17-2013, 11:10 PM   #3
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
What do you have for headers ?
2894 STK
Old 03-18-2013, 10:48 AM   #4
randall502
I haven't invested in headers yet. Still have the manifolds on with catback exhaust 21/4 pipes.
Old 03-18-2013, 02:16 PM   #5
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Running 4 quarts of low weight syn. oil will gain a tenth. Running 4 quarts shouldn't be a problem if you keep close check and don't let it get any lower. Remove as much weight as possible, low weight wheels, tires, spare, jack, etc.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 03-18-2013, 02:21 PM   #6
Chris1529
Liked 70 Times in 29 Posts
what rear gears do have in the car?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 03-18-2013, 03:19 PM   #7
randall502
I put a 3.42 rear gear and a posi unit
Old 03-18-2013, 03:34 PM   #8
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Add 4.10's
Old 03-19-2013, 01:51 PM   #9
Chris1529
I would go with at least a 4:10 or 4:30. With the OD trans, those gears would be fine unless you plans to drive long distances on the street. your 3:42 is not nearly enough gear for the strip.
Chris Bowman
1984 Mustang GT350
Old 03-20-2013, 03:26 PM   #10
Dan Fahey
Dan Fahey's Avatar
On my 95 Impala SS
It uses a 4.10 with 26 inch tall tires for racing.
Change to near 28 inch tall street tires to drive home on.
With the 4L60E tranny get near 20 mpg cruising home.
If you Trailer 4.56 with 28 inch tall slick works.
D
