You have all helped me with my stocker, I am getting closer to the index.But need more help.what I have is.
76 Camaro 350 cid 287 NHRA rated HP 350 turbo with 275 First 5.13 gears Mickey Thompson ET Slicks 9x30 we ran a 12.80 @ 102 yesterday shifting @ 7k went thru the lights @ 6500 60ft 1.71 I have the Cal Tracs bars and springs Thank You all I am happy I finally got in the 12's |
Liked 1,905 Times in 427 Posts
I'd consider going to a 2.52:1 low gear, and a 5.38:1 rear gear.
Alan Roehrich 212A G/S |
Alan I dont want to spend any money on this trans, would the 5.38 work for now I am thinking of a Pro trans later I am not sure I dont know what first gear ..
Liked 209 Times in 46 Posts
what type of converter?
Looks like you ned about .15 just in 60' 5.38 won't help that much |
Liked 719 Times in 220 Posts
Sounds like you're close, but try short shifting it about 6500 and seeing what happens. I usually don't turn a 327 that high through the gears. 5.38's to 5.13's isn't that different-5-7 % or so. You do need 60 foots in the 1.55-1.58 range, though. What class are you shooting for, and what index?
Yeah, the 1-2 shift probably needs to be about 6200-6400, at most.
The 5.38 will help if you swap to a 2.52 low gear, what's going on here is you have way too much drop between 1st and 2nd, the car is not moving fast enough, and the RPM drops too far.
Liked 3,227 Times in 981 Posts
Think Mark is on it...converter or something else needs to be addressed. That 60 ft has to get better regardless of which index you're after.
Liked 138 Times in 51 Posts
Carb tuning is a big factor as well!
#9 | |
