Old 01-24-2013, 05:40 PM   #1
FLEMING
Liked 55 Times in 26 Posts
Default Manual steering box 68-74 nova
My nova (74) came with power steering, I have been told I should switch it to one off a different car because of weight savings and it would be alot easier to steer at low speeds... What steering box would work???
Thanks in advance..
FLEMING is offline   Reply With Quote
Old 01-24-2013, 07:23 PM   #2
charlieo
Default Re: Manual steering box 68-74 nova
hi. i have a manual steering box i pulled out of my nova [71] that i have no need . if you would like to call me i will sell it 321-368 1896 cell. charlie
charlieo is offline   Reply With Quote
Old 01-24-2013, 08:31 PM   #3
Robert Simpson
Liked 20 Times in 12 Posts
I don't believe those two boxes can be swapped. The 71 is a rear steer box and the 74 should be a front steer box. Hope I am wrong. I heard that a s10 box will bolt on? Not sure.
Robert Simpson is offline   Reply With Quote
Old 01-24-2013, 08:40 PM   #4
Billy Nees
Liked 7,779 Times in 1,742 Posts
74 was last year for rear steer, it will fit.
Billy Nees 1188 STK, SS
Old 01-24-2013, 09:06 PM   #5
That wouldn't affect anything anyway, Robert. You just flip the pitman arm around 180 deg.
Old 01-24-2013, 10:20 PM   #6
Jeff Kempton
Jeff Kempton's Avatar
Liked 66 Times in 30 Posts
Not looking to hijack the thread, but since the 1st Gen Camaro and the '68-74 Nova have essentially the same subframes I figure my question fits the theme here.
I have a S10 box and am planning to use it on a '69 Camaro. I haven't pulled the pitman arm yet but was concerned that the master spline on the box might prevent the arm from simply being turned 180 degrees. From what I've just read here this should not be a problem, right? Is a different rag joint needed to connect to the steering shaft?
Jeff Kempton is offline   Reply With Quote
Old 01-24-2013, 10:51 PM   #7
Jeff , On most that I've seen, there four spots on the (output) shaft that are blank , or missing one spline. They correspond with the four spots on the arm that are not broached out .They are equidistant , so yes you can flip the arm around.
I have never used an S 10 box, but I would bet the steering shaft could be adapted using factory parts..It's the Vega that has the smaller shaft.
Old 01-24-2013, 11:25 PM   #8
Jeff Kempton
Thanks for the info Mark; now I'm more optimistic that the switchover will be straightforward.
Old 01-25-2013, 12:03 AM   #9
I meant to add: All Saginaw boxes (60's -90's) have the the same bolt pattern to the frame.
Old 01-25-2013, 09:21 AM   #10
FLEMING
Charlieo I will call you this afternoon...
Thanks fellas
