Old 12-04-2012, 03:10 PM   #1
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
Default Max Wedge info
I'm building a 440 stroker motor for a max wedge clone. The car will be street driven and make a few passes down the strip occasionally. I'm thinking of using a hydraulic roller, aluminum heads and of course the max wedge intake. Any ideas on which heads, Eldelbrock or Indy? Intakes, A & A or Indy? Looking at 10.25 c.r., 3.91 or 4.10 gear and running a 727 trans. Any suggestions appreciated, thanks!
Dennis Breeden
denbreeden is offline   Reply With Quote
Old 12-04-2012, 04:21 PM   #2
treessavoy
Liked 4 Times in 4 Posts
Default Re: Max Wedge info
Dennis Breeden
Dennis,
It really depends how much you want to spend.
If it were me and it would be primarily a street car I would go with the Edelbrock heads and the A&A crossram with Eldelbrock carbs. I'd go with the 3.91's and a convertor between 2500 and 3000 stall.
If you want to go faster at the strip you'll have to give up some driveability on the street.
JimR
Jim Rountree
Old 12-04-2012, 04:26 PM   #3
Bill Brennan
X2+ On the edelbrock heads and A+A intake.
I wouldn't got less than a 3500 stall on the convertor.
I ahd one on the street, it was a 498 " er. With 4.56's.
I ran a 4500 stall after trying many others.
Bill Brennan 1062 STK
Bill Brennan is offline   Reply With Quote
Old 12-04-2012, 04:36 PM   #4
denbreeden
denbreeden's Avatar
Thanks guys, I appreciate the response. I was leaning toward the Edelbrocks and A & A's intake. The motor is going in a 64 Savoy, should be a fun ride. Leaf springs and Cal-Tracs on the rear, upgraded brakes and aftermarket K-frame. I'll post pictures someday, hopefully by spring. I think a lot will depend on the body shop getting things done.
Old 12-04-2012, 07:58 PM   #5
treessavoy
Actually you need to talk to your cam guy about matching cam to the convertor.....the more radical the cam the more stall you'll need.
JimR
Jim Rountree
Old 12-05-2012, 12:41 PM   #6
Dads426
The edelbrock rpm heads have std port sizes, so you will need an A&A std port cross ram. Steve Magneta did a good article on a buildup of a similar motor in Mopar Muscle. The rpm heads can be ported to max wedge size, but they get thin and most shops recommend welding. The victor heads and Indy 440-1 are max wedge size, but will require a more expensive offset rocker. If the majority will be on the street, stick with the stock port.
2012 422 Allstars NSS champion
Dads426 is offline   Reply With Quote
Old 12-05-2012, 02:09 PM   #7
denbreeden
denbreeden's Avatar
Good info, I was planning on buying the Victor heads but didn't realize A & A made a manifold with smaller ports.
Dennis
Old 12-05-2012, 10:09 PM   #8
jim morgan
Liked 52 Times in 9 Posts
I have a pair of 518m heads done by Jim Morgan in Maryland
and I have a pair of bare 518m castings
Jim Morgan 1916 , 9916 STK
jim morgan is offline   Reply With Quote
Old 12-06-2012, 01:44 PM   #9
Rod Greene
Liked 242 Times in 81 Posts
440 SOURCE Super Stealth heads.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 12-06-2012, 03:16 PM   #10
denbreeden
denbreeden's Avatar
Thanks Mark,
I appreciate the info. I'm still wanting to use aluminum heads although I will stick with a standard port and the A & A intake.
Dennis
