Guest
Posts: n/a
I've run onto a 1986 Corvette that's priced right! It's very clean, everything is there, and it's modified as a nice street/bracket car with a lot of the work done and parts added already. My plan would be to run it in Pure Stock for now as it already runs the index and then build a Stocker later. NHRA has it listed as 230/300 and I believe it's a natural C car but could run D. Any advice on whether it would be a good starting point. I will say I can pick it up for under $5K and it wouldn't take much at all to make it Pure Stock legal. Never thought anyone would consider a Corvette as a dime rocket. Any advice would be appreciated!
Thanks. |
If you make it stock legal you can always run it as a bracket car. I don't think they allow Corvettes in SS/GT classes.---Trevor
I've owned a few TPI cars. They make great street engines but not good drag engines at all. The intake design is great for low rpm torque and horrible for high rpm power. Running in stock you'd be stuck with the TPI manifold. Even with a huge cam good luck getting it to sing over 6k. That would crutch your gearing really bad. Ask around to see if anyone successfully runs TPI engines in Stock.
Liked 2,436 Times in 688 Posts
That is correct......The Intake is really a restriction according
to my engine builder although there are a few quick Corvette around but not sure of exact year. |
Liked 1,772 Times in 402 Posts
The weight break is just under 10.5, so it can run D, E, and F.
The factor is high at 300, in E it needs to weigh 3170#, and run 10.80. That's tough. Yes, there are some TPI cars that are fairly quick, and successful.
Alan Roehrich 212A G/S |
