Old 08-07-2012, 10:20 PM   #1
1090 chevelle
Default Centering a rearend in a stock supspension Chevelle 1968
Is there a way to center not runing stock runing s/st like to keep car on stock side will aftermarket contral arms help thanks greg
1090 chevelle is offline   Reply With Quote
Old 08-08-2012, 07:44 AM   #2
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Re: Centering a rearend in a stock supspension Chevelle 1968
i have a 67 with similar problems. i went to my painters shop last night and they were just puttng the finishing touches on a 68 impala rolling chassis. i noticed there was a pan-hard bar across the back of the diff housing. i am thinking i will make a similar bar that will attch to my LMP diff cover stud.
Ian
Ian Hill is offline   Reply With Quote
Old 08-08-2012, 07:56 AM   #3
Lyn Smith
Liked 997 Times in 201 Posts
Been racing A bodies for 35 years.Never had any problems with" centering the rear end".Its self centering as far as i know.Just bolt it in. Been using a H and R Parts n stuff rear sway bar fo the last couple years.Will make your car leave nice and straight.Any other ? Pm me.
Lyn Smith is online now   Reply With Quote
Old 08-08-2012, 12:21 PM   #4
Steve Hayward
Are the BB cars offset a little compaired to the SB cars???
Steve Hayward is offline   Reply With Quote
Old 08-08-2012, 05:51 PM   #5
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
if you have or are planning of getting adjustable upper control arms ,you will be able to center the rear in the body of the car gmonde
Old 08-08-2012, 06:13 PM   #6
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
nope
i've had a LOT of chevelles all the rear end housings are the same from big blocks to 6 cyl as far as offset
64-67 were one width and 68-72 are 1 1/2" wider... but they all had a centered pinion
Old 08-08-2012, 06:18 PM   #7
Tom keedle
Tom keedle's Avatar
but watch your pinion angle
Old 08-08-2012, 08:34 PM   #8
Ian
The 65-70 full size cars have a panhard bar because the lower trailing arms angle in very little and the uppers don't, at all.
Old 08-08-2012, 09:35 PM   #9
Originally Posted by Tom keedle View Post
nope
Tom, the pinion in a 12 bolt is offset to the right approx. 1 inch..That's how the axles end up the same length.
Old 08-08-2012, 11:53 PM   #10
Tom keedle
Tom keedle's Avatar
but they're the same offset between 6's and v-8's
you're right about the pinion not being centered (i'm too used to ferd 9"'s)
