Liked 316 Times in 67 Posts
After popping a couple of engines this year, just trying to piece something together to finish season with whats left over. Question, with what I've got, is it better to have a gasket that fits the hole and is too thick, or perfect in thickness but a little too big for the bore?
265 SS 3.80 bore I've checked with Cometic for a better match, but being a little cheap right now trying to patch the Nomad and '57 back together Thanks in advance for any thoughts |
Liked 1,778 Times in 404 Posts
You really do not want to alter the total deck clearance too much from the ideal.
That said, "too thick" and "too big for the bore" are too vague to allow a good answer.
Alan Roehrich 212A G/S |
Liked 280 Times in 139 Posts
Back in the late 90,s we set the record and had to take both heads off, when I went to put the motor back together I packed the generic BB gaskets in the trailer(4.250 bore) as opposed to the 4.100 396 steels I took off the car. Made first round and ran the same,left them on for the rest of the year. I would go with the bigger bore gasket (283?) than alter the deck with a thicker gasket. gsa612
What he said
2009 V/SA Record Holder |
Liked 39 Times in 9 Posts
Randall, you have a pm
Reggie Winkles 2650/Stock |
Liked 351 Times in 120 Posts
Randy I have some 283 stuff, copper what do you need for thickness. I have my garage motor together yet if ron need something to run. Will be going thru Lincoln early fri morning .Tom
Tom Meyer 5240 SS Stock ??? |
Liked 13 Times in 6 Posts
Try a mr. Gasket mrg-57806 Bore is 3.870 .028 It is close and last time there was 2 gaskets in pack. for $40.
Liked 10 Times in 6 Posts
Jim, Who sells mr. gasket 57806? Tom
Tom Moock 5704 STK |
If you look up MRG-5780 on summit it goes to MRG-5780G, the only difference i can see is the G has one gasket the other two, still half the price of a cometic.
Back to the 265, the gasket we have used for years and of course is no longer available is detroit gasket 55061hg for a 305 application. Detroit sold to corteco (not to be confused with cometic) Corteco seems to have gone broke and or disappeared |
Liked 345 Times in 149 Posts
You might also look at Victor #5745 approx. 3.800 and .025 thick - I believe it's made for a 305 too.
Phil Molski PMR Performance S/C 1623 |
