Old 07-12-2012, 10:49 AM   #1
eracer36
Default Fox body help
Need some help gang, will a 30" slick fit on a 93 fox body ???
eracer36 is offline   Reply With Quote
Old 07-12-2012, 11:17 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Fox body help
Not unless you do major surgery. Both inside the wheel well and the quarter panel would need modified. Correct backspacing and wheel spacers are still needed for a 28x9 M/T on my car, as the tire is inside the wheel well. The 79-93 are the same shell. If you need any more help let me know.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 07-12-2012, 11:44 AM   #3
HR9121
HR9121's Avatar
I run the 30x9" Hoosier radial on my '87, just one thing you need to make it work. 10# hammer will do the trick.
James Williamson
W200 J/SA. SS/JA
Old 07-12-2012, 08:03 PM   #4
Capri
Liked 27 Times in 14 Posts
All depends on the roll out of the tire. You need something with a short roll out if you dont want to do any major surgery.
Sean, are you running the 10" wheel? I run an 8 1/2"
Capri is offline   Reply With Quote
Old 07-12-2012, 08:31 PM   #5
Sean Marconette
10" with 6.5" BS.
29.5x9 fit with this wheel after painting the car.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 07-12-2012, 11:16 PM   #6
6031 stock
29.5 radial fits but very tight ... slow when you turn trust me
Marshall Greenwell K/SA
6031 stock is offline   Reply With Quote
Old 07-12-2012, 11:27 PM   #7
Notch1320
10" wheel with 6" BS works great with drum brakes, and 6.5" BS for most disk brakes. Like others have said, BFH to the inner wheel well, and about an inch pie cut below the belt line in front and a half inch pie cut in the rear and you will be golden.
Others have run a 8" wheel with 5.5" BS with no cutting...
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 07-13-2012, 09:54 PM   #8
eracer36
Thanks everyone for the help...
Old 07-13-2012, 10:23 PM   #9
Chris1529
Liked 70 Times in 29 Posts
I didn't want to trim mine any, so i stuck with 28's. 8" wheel, 5.5 bs.
What rear gear do you guys run with the 29.5 or 30's? - 5.13?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 07-13-2012, 10:56 PM   #10
partsbob67
Liked 79 Times in 11 Posts
4.56 in mine. i run the 8" wheel and had to trim the back of the wheel lip.
bob beals 7244
partsbob67 is offline   Reply With Quote
