Old 07-31-2012, 06:56 PM   #1
R Hoffman
R Hoffman's Avatar
Default What 3rd Gen F-body Flexplate and Trans shield?
I'm ready to install my ATI TH350 in a 92 Camaro and was looking for some input as for what flexplate andTransmission shield fits in the factory tunnel.
Thanks for any help!
B. Hoffman
n/a
R Hoffman is offline   Reply With Quote
Old 07-31-2012, 08:03 PM   #2
Liked 1,912 Times in 429 Posts
Default Re: What 3rd Gen F-body Flexplate and Trans shield?
Get the CSR "carbon fiber" type all-in-one "form fitting" shield. It leaves the most possible room in the tunnel. I strongly suggest a Lokar locking type stainless braided filler tube and gauge. If the oil cooler circuit on the transmission is not "looped" on the inside, I also suggest short lines extending from the fittings on the case out past the shield, to allow you to quickly and easily disconnect the cooler lines. Access to the filler tube and cooler line area is always seriously restricted by a shield.
Old 07-31-2012, 08:09 PM   #3
Ed Wright
Ed Wright's Avatar
I have the TCI flex plate shield that goes inside the bell housing area. The smaller flex plate is required. The dowel pin bosses inside need relieved to clear the shield. Takes up no room outside.
I also use the Locar locking dip stick & tube.
Ed Wright 4156 SS/JA
Old 08-02-2012, 06:21 PM   #4
R Hoffman
R Hoffman's Avatar
Thanks for the replies!
n/a
