Old 06-25-2012, 03:59 PM   #1
dussault.racing
Default santhuff / control arm modification question
Does anyone have a picture of what needs to be cut on 69 camaro control arms to use Santhuff shocks???
dussault.racing is offline   Reply With Quote
Old 06-25-2012, 04:29 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,904 Times in 571 Posts
Default Re: santhuff / control arm modification question
I dont have a picture. I used a hole saw to cut out the entire center of the a arm then I welded in 2 new tabs to bolt the shock to. The shock needs to move outward to give enough room for the adjustment knob at the bottom of the shock. I pulled the a arms out to do the mods. I also used the bracket supplied by Santhuff for the lower mount to the a arm. It was a pretty easy install if you can weld and fabricate. you will also need a snubber so the shocks will not extend too far. Great shocks. They will absolutly control the front end bounce.
Mike Pearson 2485 SS
