Old 06-23-2012, 04:06 PM   #1
Tim Lisson
Default Rear Brake plumbing
Best method?
I installed new disks on the rear of my car and converting the plumbing to 03AN stainless flexible line. My T block is 3/16 for hard line. Does someone make a fitting that is 03AN to 3/16 inverted flare? Or do I have to install hard line and by an adapter from hard line tube to 03AN?
Thanks for the help in advance!
Tim
Tim Lisson is offline   Reply With Quote
Old 06-23-2012, 05:42 PM   #2
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Default Re: Rear Brake plumbing
Hi Tim
I don't know if anyone makes that fitting?
We ran hard line from the T block out to the end of the housing tubes,
then an adapter and a shot braided line to the caliper.
Glen
MEXJOE is offline   Reply With Quote
Old 06-23-2012, 06:01 PM   #3
Tom Moock
Liked 10 Times in 6 Posts
speedway motors in lincoln, ne. www.speedwaymotors must sell fitting because i have braided line from t block on my malibu. Ron Taylor installed the brakes and i known he got the parts there.Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 06-23-2012, 08:17 PM   #4
Doug Blackley
Doug Blackley's Avatar
Tim, talk to Brian Van Poppel. I did this same converion last year and he can hook you up with all the fittings and mounting clips for them. You can e-mail him @ mdperfspec@yahoo.com.
Doug Blackley 1697 STK
Old 06-23-2012, 10:45 PM   #5
Tim Lisson
Thanks guys. I found some 03an to 3/8 24 through Jegs. They are on there way here!
Tim
Old 06-24-2012, 09:27 AM   #6
tj310
I just did a similar conversion , it's easier , and cheaper to use -4 connectors. Just a heads up for anyone who hasn't bought lines yet.---Trevor
