Old 06-18-2012, 11:09 AM   #1
JohnRoderick
JohnRoderick's Avatar
Liked 11 Times in 4 Posts
Default Strange Master Cylinder Plumbing
What is the best way to connect 1/4'' hard tubing (7/16'' 20 IF fitting) to a Strange master cylinder (1/2'' 20 IF fitting). I upgraded to a Strange master cylinder and I want to connect the 1/4'' stock rear brake hard tubing directly to the master cylinder, but I can't seem to locate the proper fitting. I have called Strange's and Summit's Tech. Support , but they have no solutions. I found a fitting at AutoZone and Napa, but the 1/2'' 20 IF part of the fitting doesn't seem long enough to get a proper seal with the master cylinder.
JohnRoderick is offline   Reply With Quote
