Liked 329 Times in 177 Posts
I have one of them kinda a 92 or so electric smog/vacuum pump used to create vacuum for the power brakes----What year/s and models did these come on ???need one for a street rod project---seems like certain Corvettes mighta had them too--Thanx for the help ---FED387
#2 | |
Liked 1,538 Times in 575 Posts
are these electric?? wanna put it in a remote place not on the firewall--- why this pump instead of the GM pump??
#4 | |
If you plan to use a PCV valve, use P/N E5ZZ-6A666-A; is designed for boosted applications. Also, there is a good GM pump if you can find it; P/N 22062562, and the electric connector is P/N 12085485. This pump was used for brakes on Buick GN and some Cadillac applications. Last edited by SSDiv6; 06-22-2012 at 08:55 AM. |
Liked 410 Times in 94 Posts
Look under Cadillac / Northstar parts
