Which coil is best and why? Double the price for the HVH. Why? I have used the pro power for years. Pros and cons to either?
Kenny 7709 ?/sa |
Liked 2,510 Times in 701 Posts
We run HVC on all our cars. Seem to last better and perform better.
Had to take two degrees timing out compared to Pro Coil. No clue why but did. When do we find out you new car combo? ..... Inquiring minds want to know. Good Luck! Irving Family Racing |
Liked 165 Times in 51 Posts
Is this always the case or will it vary for different combinations.
Liked 13 Times in 3 Posts
Pat, I am using a 7al-2 with a 8201 coil, but I also have a 8261 coil. Would I be better off using the 8261 coil? I have two of the 7al-2's and both of them are probably 10 years old. Are there any performance gains if I had you do any upgrades to these boxes? I cant say that I feel like anything is wrong with the box I'm running, and the other one wasn't having any problems last time I used it.
Thanks, Chuck |
Liked 129 Times in 59 Posts
Pat,
Would this also be the case with a 6-series ignition (#6421) and the HVC-2 coil (#8253)? The output information on the MSD website suggest this is an acceptable combination. Thanks! Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
#6 | |
I guess what I was asking was, Rather than the combo of MSD components...
Would you see a difference for a specific engine combo due to combustion chamber style shape etc. Or will you automatically need to lower your timing 2 deg. with this coil Here is my situation. I did not dyno with my MSD setup THAT IS IN MY CAR. THE MSD ON THE DYNO USED A 7AL2 AND A PRO POWER COIL. I have the 6AL and the 8252 coil in my car. Thanks Quote:
Thanks, Pat!
#8 | |
Thanks!
I'll see if we can use our stuff on the dyno next time. Quote:
Liked 460 Times in 91 Posts
Techwest Racing Services updated my MSD and its works "GREAT". Thanks Pat............They have thier Sh**t together.
Bob Bender 144 O/SA 2010-2012 National Record Holder |
