Liked 20 Times in 15 Posts
NHRA has listed two HP specs for the '76 318, 140 and 150. Both have the same cam, intake, carb head etc. Am I missing something or is this a typo for the 318-4v that shows up in later years? Thanks
78 is first year of 4 Barrel 318. Do not know why 76 should have diff. ratings.
I think the four barrel combo is better way to go. |
Liked 25 Times in 16 Posts
I think Chrysler rated the engine differently in different cars. Sort of like the Corvette engine was always higher than the same engine in a Camaro. Maybe exhaust manifolds make a difference too?
Mopar 2 Ya! |
Liked 404 Times in 158 Posts
Single/dual exh, maybe different veh's and manifolds as previously mentioned, hard to say. With some fords it was 2bbl carb or 2bbl variable venturi style carb had different ratings for essentially the same engine.
Regardless, both engines are lumped together and are rated at 190hp. (I checked a 76 dodge 318) |
