Old 04-09-2012, 04:44 PM   #1
powerstrokeace
Default throttle stop Timer #1
Guy's just wondering when you turn on the first timer for super comp in a car that can run any where between a second and a second and a half under the index. made a lot of changes and really never had a handle on this
Ace
powerstrokeace is offline   Reply With Quote
Old 04-09-2012, 05:52 PM   #2
Chris Williams
Chris Williams's Avatar
Default Re: throttle stop Timer #1
I've tried several times, including a whole lot of time at .000 in our hardtail. Now we're on the stop at .020 in our four-link car. Feels just about right. Of course, your-mileage-may-vary
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 04-11-2012, 11:31 AM   #3
Charlie Yannetti
Liked 192 Times in 83 Posts
Not sure of your combination, but my old S/C was capable of running 7.60's off the stop.. when using the stop, it came on at .100, and the car shifted on time at 1.25 into the run.. I didn't want to shorten up the first timer cause I was afraid of it affecting reaction time, but you could try shorter if you have too much time in the box..
Charlie Yannetti is offline   Reply With Quote
Old 04-14-2012, 08:46 PM   #4
powerstrokeace
Well this is the very reason that I'm searching this out. we had very little luck last year with our four link car. reaction time suck bad with .010 in the box. But I'm looking at maybe .100-.250 and shifting at .500. we never ran this car all out since out purchase and never rally knew what it could do. This winter the motor was freshend up and a new bigger cam was selected to maybe get more MPH out of this thing. So we are starting from scratch as you can see.
Ace
Old 04-29-2012, 08:06 AM   #5
S/C 302A
S/C 302A's Avatar
My hardtail ran 7.70's. I had the most consistant luck going on the stop @ .30 & shifting @ .80. I tried it @ .10, and had a little more mph, but "my combination" was more consistant @ .30.
Dave Livesey
2007 Midwest Super Comp Series Champ
S/C 302A is offline   Reply With Quote
Old 05-07-2012, 03:51 PM   #6
voltdr
Liked 100 Times in 51 Posts
I think this is a good starting point. You want just enough time at full power to get the car out of the beams. I use .25 shift at .8 on my hard tail car that runs low 7.60s all out.
Dan
voltdr is offline   Reply With Quote
Old 05-08-2012, 12:25 PM   #7
Barney B
Barney B's Avatar
My American I run .100 in the start timer and shift at .50 I run around .065 to .070 in the box. Car runs 7.60's all out
BB
Barney B is offline   Reply With Quote
