Old 04-30-2012, 08:37 PM   #1
40Coupe
Default Transmission catch can placement
What type are you using and where are you mounting it in a door car. I'm struggling with an inconspicuous clean looking place to mount it and also a place that won't potentially put fluid in front of the tires if happened to overflow.
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 04-30-2012, 08:43 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Transmission catch can placement
Never used/needed one.
If you're puking fluid, you're got a problem that needs to be fixed not catched.
Old 04-30-2012, 08:48 PM   #3
KRatcliff
Liked 534 Times in 143 Posts
If you are not puking or leaking fluid out of a racing transmission just means you haven't put any in yet.
KRatcliff is offline   Reply With Quote
Old 04-30-2012, 08:57 PM   #4
40Coupe
It's not currently puking and never has. The vent under the shield has been plugged and a new vent tapped in the rear portion of the case. That's a much lower place on the trans and it has been recommended to me to put a catch can on it. This is a new setup and I don't want to put fluid down and learn the hard way. Just being proactive.
'67 Camaro
1.25
5.77 @ 118
Old 04-30-2012, 09:00 PM   #5
KRatcliff
I put mine on the firewall on the passenger side. Any fluid that might make it up there drains back slowly.
Old 04-30-2012, 09:13 PM   #6
1320racer
1320racer's Avatar
Why? My vent remains in the stock location and it too is under the shield as it has been since I first starting using a shield 13 years and thousands of passes ago, all without puking a drop.
Do as you wish with your car, might want to install a parachute too.
Old 04-30-2012, 09:33 PM   #7
40Coupe
That's a mystery and I don't have any clues but am doing what has been recommended since the vent is in that location.
'67 Camaro
1.25
5.77 @ 118
Old 04-30-2012, 09:37 PM   #8
1320racer
1320racer's Avatar
be careful of who you listen to, there's no reason to be plugging the stock vent and relocating it on your trans!
Old 04-30-2012, 09:59 PM   #9
Liked 17,488 Times in 1,595 Posts
40Coupe,
I use one on my stocker. I run line from the factory vent to the trunk. I can access it easy and it has a long line to drain back. I have never had and issues with my C6, but the C4 always left a little in the can when hot lapping.
You can run a line tight to the tunnel and back into the trunk for a clean look. I use a polished aluminum can with a breather, looks nice and its out of the way.
Old 04-30-2012, 10:06 PM   #10
40Coupe
That would be a good problem to have. That would mean I tripped 150 MPH in the 1/4, a really good problem. LOL
'67 Camaro
1.25
5.77 @ 118
