Old 01-30-2012, 07:27 PM   #1
Duane Eiskant
Thumbs up Fuel Injector Size HELP!!
I hope this is an acceptable post?
I am currently working with a friend on a 2010 Camaro street car project that will see a small awount of time at the dragstrip. We have a LS based 427 cubic inch engine with a F1C Procharger that has a 92mm throttle body and a Fast LSX-R intake manifold. It is a pump gas engine with a 560 lift, 232 degrees duration at .050, Comp Cam and All-Pro aluminum heads. Boost will probably be in the 15 to 20 psi range. It will be tuned with HP Tuner through the stock ECM. Any suggestion on a size for the fuel injectors? I know its not stock or super stock, but there seems to be many knowledgable people on this site that I know can give accurate suggestions!
Thanks for such a great site, Duane
Duane Eiskant is offline   Reply With Quote
Old 01-30-2012, 09:01 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Fuel Injector Size HELP!!
I have no idea but Ed Wright of Fast chips is the man to talk to. Throw that HP Tuners stuff in the trash and call Ed. I would bet with his tuning it runs faster with less problems. I dont even waste my time fooling with mine when I make changes. I just box the PCM up and send it to him.
Old 01-30-2012, 09:18 PM   #3
Ed Wright
Ed Wright's Avatar
Thanks Rob. (blushing)
Duane your going to need about 75 lb injectors. I have honestly never tuned a 20 psi 427". Should be a beast. Good luck.
Ed Wright 4156 SS/JA
Old 01-30-2012, 10:07 PM   #4
rawhide
Liked 7 Times in 5 Posts
Duane,
Ford Racing offers an 80 lb set under the part number M-9593-LU80.
regards, Roland
rawhide is offline   Reply With Quote
Old 01-31-2012, 01:44 PM   #5
Ed Wright
Ed Wright's Avatar
Those should be good.
Old 01-31-2012, 04:35 PM   #6
Duane Eiskant
Smile Re: Fuel Injector Size HELP!!
Thanks Guys,
Ed, is there a phone number I can use to give you a call.
Again, thanks for a great site! Duane
Old 01-31-2012, 11:11 PM   #7
Rob Petrie E395
I just wish you still had the chassis dyno. Best money I ever spent.
Duane its your fault I even know Ed. If you had not told me to take my car to Midnight madness all those years ago at Calhoon's it would still be bone stock and I would not have needed his help. I would still be trying to kill myself with that boat I had. I will admit I do feel alot safer at 135 in my car than I did at 135 in that boat. LOL. His number is on his site Fastchips.com
Old 02-01-2012, 12:17 AM   #8
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Hey Rob, just sent you a text........
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 02-01-2012, 02:53 AM   #9
Rob Petrie E395
Got it. I never even thought about that LOL.
Old 02-01-2012, 09:16 AM   #10
Ed Wright
Ed Wright's Avatar
918-446-3019. 9:00 'till 5:00, Mon thru Fri
Most of the time, anyway. :-)
Trying to kick back a little.
