Old 01-30-2012, 08:06 PM   #1
ken robinson
Liked 225 Times in 88 Posts
Default Min. allowable tire clearances
Looking for some ideas on what the min. allowable rear tire clearance should not exceed . From the inside of the rear slick to the leaf spring . Its a 1969 dart stocker and the leaf spring is the only thing that limits how far in the tire can go . Your opinions / expearences please . Ken R . ..............
Old 01-31-2012, 01:12 AM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Min. allowable tire clearances
Is this a Stocker? On my Volare' (F Body) I have 3/8" from the widest part of the tire to the leaf spring. This is using a radial Hoosier. I would give at least 1/2" to 5/8" if bias tire is used. Jim
Old 01-31-2012, 10:24 AM   #3
terry1
Liked 24 Times in 13 Posts
Smile Re: Min. allowable tire clearances
Jim,don't you think that a bias tire would only get narrower as the speed increases?
The reason I'm asking is that I have/will have a similar issue.
terry1 is offline   Reply With Quote
Old 01-31-2012, 11:47 AM   #4
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Min. allowable tire clearances
Calvert has a narrower spring available for the Darts.
2009 V/SA Record Holder
Old 01-31-2012, 08:56 PM   #5
ken robinson
Thanks guys for the info/input what a great sport to be part of ! I was thinking 1/2 inch would be safe enough , with a hooser radial tire and the caltac set-up that the friend/racer has supplied us for his stocker c/sa dart .The goodyears seam to have alittle less side wall bubble compaired to the other tires , at least thats want I know from what I ran on my 67 camaro . I don't build alot of cars , but the once I'm apart of I want wright and mopars are not my back round . It would be nice to see some of my work go rounds .
Old 02-01-2012, 12:01 AM   #6
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
I have more piston to wall clearance than my Goodyears and the springs. It's annoying having to touch up the paint on the springs every year but the tires seem okay. I think they only contact making turns.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 02-01-2012, 02:34 AM   #7
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Kenny,you going over to the dark side?You in a Moopar?I gotta see it.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 02-01-2012, 03:46 AM   #8
Jim Wahl
Jim Wahl's Avatar
Sure, it gets taller but it flexes at the sidewall a bunch more. The radial holds its height and width much better than the bias. Jim
