Old 03-30-2011, 08:53 PM   #1
BobUnkefer
BobUnkefer's Avatar
Default 1st gen Camaro bushings
Danged if I can find the thread that's in here somewhere on the best setup for front end bushings for 67-69 Camaro's.
Do remember that the general opinion was to stay away from poly bushings. But don't remember what/who had the best pieces.
Would like to redo the front end on my '68 and looking for input.
Appreciate your feedback
Unk
Bob Unkefer 4409 STK
BobUnkefer is offline   Reply With Quote
Old 03-30-2011, 10:05 PM   #2
Liked 1,827 Times in 414 Posts
Default Re: 1st gen Camaro bushings
Bob, Del-A-Lum, from Global West, for the bushings, TRW or Moog for upper control arm shafts, and TRW or Howe for the extended upper ball joints.
Old 03-30-2011, 10:22 PM   #3
BobUnkefer
BobUnkefer's Avatar
Alan,
I've looked at the Del-A-Lum bushings, do I need the offset shaft? or is the TRW Moog shaft all that's needed, and why not the offset shaft?
Appreciate the reply, thanks.
Unk
Old 03-30-2011, 11:45 PM   #4
Liked 5,121 Times in 1,952 Posts
Bob , The offset shafts should give you a few more degrees + caster without too much - camber (by using more alignment shims on the rear bolt)
Old 03-31-2011, 12:33 AM   #5
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Alan, im just wondering what do you find to gain by using a extended upper Ball joint on the
front of a Camaro ?
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 03-31-2011, 11:12 AM   #6
I like the offset upper shafts to get a better range of adjustment for caster and camber. I like to see zero camber at race height, going down the track, with a lot of caster so the car wants to go straight and keep going straight, with minimal rolling resistance. If you can get plenty of caster, you can run as close to possible to actual zero toe, without wandering.
The extended upper ball joints help to correct the camber curve, so that the amount of camber change during front end travel is reduced.
Old 03-31-2011, 11:17 AM   #7
Greg Barsamian
Liked 419 Times in 96 Posts
Unk, Contact Alf Wiebe: wiebemetal@shaw.ca,
Old 04-01-2011, 09:34 AM   #8
B Aceves
B Aceves's Avatar
Since they are legal in stock now I would strongly recommend these adjustable tie rods and
get away from any type of heating to the Spindle for Bump Steer adjustment.
Bob Aceves,
746 E/SA
A&M motorsports
Old 06-08-2011, 08:37 PM   #9
3860
Sorry to drag this old thread back up. I am having the issue with the camber change with front end travel. Does anyone know the part number or source for the extended upper ball joints? Thanks
BTW it's a 67 Camaro
3860 is offline   Reply With Quote
Old 10-21-2011, 12:47 PM   #10
jrod2sc
Alan,
How do you determine which available stud length works best with the extened upper ball joints (my particular set up is for a '68 Camaro)?
Just by looking at Howe's website, there are a few stud length options to choose from.
http://www.howeracing.com/p-7926-how...oog-k5108.aspx
Many Thanks.
jrod2sc is offline   Reply With Quote
