Old 09-08-2011, 01:00 AM   #1
Brett Brown
Liked 5 Times in 2 Posts
Default 327 vs 283
How much more hp would you expect to make from a 327 vs 283 (using same cam, carb & cylinder head)?
Brett Brown 7257 STK, SS, COMP
Brett Brown is offline   Reply With Quote
Old 09-08-2011, 01:16 AM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: 327 vs 283
Should be almost the same assuming the valvetrain can handle the extra RPMs.
Paul Precht is online now   Reply With Quote
Old 09-08-2011, 08:46 AM   #3
Tom Meyer
Liked 354 Times in 120 Posts
Using 500 for a good 283 SS engine, math comes out to 1.76 per cube times 44 more rounds out to about 77 more hp. Have never ran one maybe someone could tell use what a good 250 hp 327 makes. Tom
Tom Meyer 5240 SS Stock ???
Old 09-08-2011, 08:55 AM   #4
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: 327 vs 283
A 327 will have a lot more torque than the 283. Also, using the same heads( I assume a set of #520's), the 327 has a drastic compression edge.There is a Div. 7 racer, a Mr. Solano, that has a blue 64 Malibu hardtop with a 327/250 horse combo running in J/SA that has gotten into the 11's pretty handily, that with the 4 jet and all. The 68 low compression 250 horse engine isn't anywhere near as good in bad air. It falls on its face pretty markedly. The 283, however, will make RPM like nothing else.That's where the horsepower comes in.
Old 09-08-2011, 09:03 AM   #5
ss wannabee
Liked 7 Times in 7 Posts
Is this a STOCK or SS question? Interested in the SS side....
ss wannabee is offline   Reply With Quote
Old 09-08-2011, 11:16 AM   #6
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
In my SS car with the car weight real close to the same the 327 250/258 is about 2.5 tenths faster than the 283 220/230 which uses the same heads, intake and carb. I don't know the actual HP numbers but that is what they are on the track for our car and motors.
The 283 makes the power about 1000 rpm higher than the 327.
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
Old 09-08-2011, 11:34 AM   #7
67chevygary
Am curious as to wether the 590 heads have a distinct advantage over 896-460-or 523 heads?
67chevygary is offline   Reply With Quote
Old 09-08-2011, 05:25 PM   #8
RPinoski1
Besides 8 HP, anyone know what the difference is between the following 327's ?
This is for SUPER STOCK
63-64 327 250/262
and
65 327 250/270
"I've never seen a Hearse with a Luggage Rack, You Can't Take it With You" Mike Ness
RPinoski1 is offline   Reply With Quote
Old 09-08-2011, 05:40 PM   #9
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
63-64 327 250/262
and
65 327 250/270
YES..
62/64 327 ran 283 Power Pack heads with 1.72/1.42 valves
65 - 327 used larger 1.94/1.5 valves which are perfect valve size for that size engine.
D
Old 09-08-2011, 05:45 PM   #10
RPinoski1
I see it now...I wasn't looking down the sheet far enough.
