Old 09-09-2011, 10:39 AM   #1
Greg Hill
Liked 279 Times in 68 Posts
Default What are you all paying for Sunoco Purple?
How much are you paying for Purple by the drum? I had a guy quote me $415 or $7.65 a gallon which is $85 more than I paid in the spring [$330].
Greg Hill 4171 STK
Old 09-09-2011, 10:41 AM   #2
Casey Miles
Liked 495 Times in 91 Posts
Default Re: What are you all paying for Sunoco Purple?
Last time I went to the pump, it was $7.05 a gallon. It's always fresh at this station also, it's right down the block from County Line Dragway.
Casey Miles
248H Stock?
Old 09-09-2011, 10:52 AM   #3
Ron Middleton
Liked 12 Times in 4 Posts
I bought 2 drums earlier this year at $360 per drum
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 09-09-2011, 11:08 AM   #4
Liked 1,811 Times in 412 Posts
Greg, you'd have to call Kevin and ask him, he'd know what we pay, and be glad to tell you.
Old 09-09-2011, 11:11 AM   #5
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Originally Posted by A56 View Post
Has anyone tried the 112 Blue ?
Conventional wisdom would say that more octane would be slower in an engine that doesn't need it, BUT I think there must be some other properties about it that's better than the 110 Purple. It runs exactly the same in my lil' 4-cyl car, but seems to be about .03 quicker with the old 360 Magnum crate motor I had.
We back-to-backed 112 Blue with C12 in Fisher's Mirada, and the E.T. didn't budge -- but it's cheaper, and more stable than the VP.
As with any fuel swap, you may have to play around with jetting to get the absolute best out of it. But, given the research I've done, I choose to run Sunoco Blue 112 full time in everything I have.
For those in the east, call Danny Presnell at Bearden Oil, 800-704-1233, to find a distributor near you.
Old 09-09-2011, 11:40 AM   #6
I was paying $50 for a 5 gal pail from the local auto parts store, about 3 - 4 months ago they raised it to $60. Last weekend I was at Infenion Raceway and the have sunoco out of the pump in the ground. They have most all of the varietys but not the purple 110 so I bought the 112 blue. It was only $7.99 a gallon, I bought 15 gallons. I was buying it from the Auto Parts store cause it was easy, but now there really ripping me off, so im buying the 112 blue for now on, that is if it runs OK in the car. Has anyone tried the 112 Blue ?
Mark Lelchook
E/SA #704
Mark, Sunoco blue runs fine, we switched from VP C-12, since C-12 got absurdly expensive, and would regularly fail fuel check right out of the new drum on the VP trailer at the race track.
While "extra octane" may in fact be "wasted", the HP effect people see, if they properly jet for changes in the specific gravity of their new fuel, is due to the burn rate, not due to octane. The various fuels have fairly widely varying burn rates. For example, some engines with only 12.2 to 1 compression ratio may see a HP gain by switching from C-12 to C-14+ or C-25, simply because the burn rate in the other fuels is what "makes their engine happy". You would not think that would happen, given the accepted theory that "extra octane is wasted", since C-14+ is rated for 14 to 1 compression, and C-25 is rated for 15 to 1, as well as high RPM (for Comp eliminator and Pro Stock). But it does.
Old 09-09-2011, 11:55 AM   #7
Duster 7695
Liked 8 Times in 6 Posts
I use to pay $7.00 a gallon at the station accross from Firebird. About two months ago it went up to $8.00. I just got some yesterday and it is still $8.00.
Mark,
I always run the Purple110. Infineon said they sell Sunoco, so I did not bring any with me. Last year I got to the Divisional and found out they only have 112. I had to drain the fuel system and use the 112. I did not notice any change in performance or the A/F ratio with the 112. I run a low compression 360 in my Duster.
Raul
Duster 7695 is offline   Reply With Quote
Old 09-09-2011, 11:59 AM   #8
Casey Miles
Smile Re: What are you all paying for Sunoco Purple?
I had some old Purple and when I went to fuel check, it passed, but lost most of it's color. The tech official told me to put some fresh Sunoco purple so that he could identitfy it by the color that I was claiming. I'm thinking that it was at least 1 year old fuel, when I was at the PRI show, I spoke to a Sunoco Representative, he told me that it has a 2 year shelf live on the purple fuel.
Casey Miles
248H Stock?
Old 09-09-2011, 12:02 PM   #9
Michael Beard
What Alan said. There are more variables in fuel than just octane. Octane doesn't make power. Octane *allows* you to do different things with the engine that make more power. By itself, octane amounts to nothing more than "unburnable stuff", which allows you to run more ignition timing and/or compression without getting into detonation. Theoretically, the less octane the better, but again, you have to look at ALL of a fuel's attributes to determine it's efficiency and power potential in a given combination.
Here's an old chart that has a lot of different fuel properties listed... http://www.smithtex.com/racing/fuelcomp.html
Old 09-09-2011, 01:22 PM   #10
Gordie Kissner
Liked 18 Times in 10 Posts
We pay 6.45 a gallon with racer discount in Boise for 110 Purple, thats with your own container.
Gordie
Gordie Kissner
SS 6010
STK 6010
Gordie Kissner is offline   Reply With Quote
