Old 08-11-2011, 11:00 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default 383 2bbl carb
383 2BBL carb for a '65 B Body. Looked a NHRA specs, I'll assume that any 2BBL is acceptable as long as its tranny specific. Any suggestions what one works the best? Anyone a guru on this set up? Thanks
House of Darts is offline   Reply With Quote
Old 08-11-2011, 11:12 PM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Default Re: 383 2bbl carb
It has to be the same make, model and throttle bore size. Does not matter if it was produced for the auto or manual tranny or correct serial number for a specific combo. Jim
Old 08-12-2011, 08:59 AM   #3
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
The spec gives you throttle bore size, that is what they go by,. I cant remember the cfm on them but some where around 350 I think. Holley makes a 350 cfm carb and they can be made to flow more than that. Find some old carbs and start the measuring process and find out if the holley is accepted.
Bob Pagano A/SA
Old 08-13-2011, 03:02 PM   #4
Chris Barnes
That combination is going to be even more challenging than our dinky 525 cfm Carter. Finding rebuildable cores is only the first hurdle. Make, model, throttle bore measurement-only requirement is correct. That makes the job easier. There is definitely a best carb for the application. Which one is it? It would be great if it was a Holley.
I have daily driven a few 318 Poly 64-66 B cars with the 2 bbl and they seemed to really work with a little attention. I'm almost sure they were Carters.
Good Luck
Chris Barnes
Wagons of Steel
Chris Barnes is offline   Reply With Quote
