Liked 6 Times in 5 Posts
Found out that the oil pressure with 20/50 wt when rev engine goes to more then 90 pounds also heavy spring in oil pump?
Thanks James!!!
Liked 263 Times in 68 Posts
Why are you using that heavy oil? Try 10W-30. You don't have a top fuler do you? Use synthetic racing oil.
John Dinkel 3295 STK |
Liked 1,802 Times in 411 Posts
Way too much oil unless that's a Cleveland. Even 5W 30 synthetic is plenty.
Alan Roehrich 212A G/S |
No Top Fuler, Would not have one of those oil down track junk!!!! Its a bracket car 400 small block 10.20 at 131.89 at wt 3160. Thanks Guys, You all are the Best!!! What wt of oil do you all like?
Liked 304 Times in 102 Posts
I'm guessing you have HV pump with about .0015-.002 bearing clearanceGo to 10-30 or 20 may lower when warm. 90 lbs won't hurt anything besides taking a little power or worst case wear dist. gear. If oil does'nt drop psi enough to suit you change spring or pump.
I've been using 10W30 and 20wt for a long time. Mike Taylor 3601 |
I don't know why they even make high volume oil pumps for the sbc. Absolutely no need for them. But, if you make them somebody will buy them.
Ed Wright 4156 SS/JA |
Banned
Ed:
I know for a fact that Fadely & Edwards ran HV + HP Fadely had a supply of the old trans-am oil pump springs with a .125 shim = 85 to 90 hot and Pennzoil 20-50, I had the deep rotor (from 534 Ford Truck engine) covers machined at one of the Ford Machine shops. The 351-Cs need alot of pressure. |
#9 | |
I'm going out to the shop and put in the 5/20 wt and see if that does the FIX.
