Old 04-30-2011, 03:53 PM   #1
Phillip marvetz
Phillip marvetz's Avatar
Default Need help with Erson cam I.D
Hey Guy's,
I'm putting together a junkyard 440 for a duster and need help with an old Erson cam that's been hiding on the shelf for a decade or so. It has hf11h stamped on the back. I think it's an old .484 lift cam but I found this one when I was looking for a old Mopar Purple cam and found 2 cams. The other doesn't have any marking's so now I'm confused as to which is which. Anyone know what the HF11H is?
2009 V/SA Record Holder
Old 05-12-2011, 01:12 AM   #2
trmnatr
Default Re: Need help with Erson cam I.D
Originally Posted by Phillip marvetz View Post
Hey Guy's,
HFIIH?????
HF stands for Hi-Flow series of cams
If so, E410521
306/306 @ Lash Duration (Erson's seat # they use)
235/235 @.050"
.472"/.472"
108° lobe center
Now days it has zero advance ground in it
trmnatr is offline   Reply With Quote
Old 05-12-2011, 02:06 AM   #3
Phillip marvetz
Thanks for the info, Sounds like it will be fine for a stock 440 in a Duster.
Old 05-14-2011, 07:55 PM   #4
BillK
Liked 30 Times in 17 Posts
Phillip,
Shoot an e-mail to Eric at Erson and he will tell you exactly what it is and if it is compatible with what you are trying to do His e-mail is ebolander"at"pbm-erson.com Put the @ symbol in place of the "at" He is very helpful.
Bill Koustenis
BillK is offline   Reply With Quote
