I ran my 283 stocker this past weekend at MIR. ( L/SA )
Shut it down at top end after run and checked plugs ,they look like they just came out of the box. I run the 4-gc carb . My question is ,do i need to jet it up or maybe leave it alone since the weather is going to change to hot conditions very soon here. The weather was very good this past weekend except for the humidity. And if i change jets is it going to pick the car up very much if any ? It seems to be sort of laying down at top end now (good fuel pressure at top end ) , but not popping or snapping ,just lazy feeling from just past the 1,000 ft mark to the 1/4. It ran a 12.18 @ 108 mph. Thanks in advance for any info....
Danny Waters, Sr / 73 Duster "340" |
Liked 460 Times in 91 Posts
I do not have anything trick but, I have a rich and lean carb I use. What you said it sounds lean. That 4GC is a pain to jet at the track so get another and faten it up a little.
Bob Bender 144 O/SA 2010-2012 National Record Holder |
What jets did you have in for that run? Dean Oliver is the guy to talk to about 4GC's, I have tried a multitude of different jet set ups and have found very little performance gain in the the 4GC. I have 67/69 jets in now and will likely end up with 68's in all. As for laying down at 1000 ft, it's a 283 all my car does on the top end is make noise!
Glenn |
I ran 64/66 jets when I ran the 283
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
I have 65 and 67's..
It ran 108 mph and 7.64 @ 88 in the 1/8
Liked 91 Times in 51 Posts
FWIW....We learned a lot on our local chassis dyno. We used the shop's O2 sensor in my O2 sensor bung. I do have headers extensions on my super comps. The key is...we took our Computech weather station with us and documented the CF, DA, etc. We jetted for 13.0 AFR. Now, we run the jet program on the Computech and it tells is whether we need to go up or down 1-2 jet sizes. We dyno'd at 2600' DA (dont remember the CF at the moment), and now we have our baseline. We know if we'll slow down or pick up based on the weather if we dont change jets. It took 2 hours and $150 which beats beating our head against the wall trying to repeat testing on the track for old school mph jetting.
IMO, reading the plugs is hit and miss. I only read them for the heat stripe (hot/cold) and base ring for jetting. Clark Last edited by cad; 04-12-2011 at 10:41 PM. |
What was the RPM at the 1000ft and finish line?
2009 V/SA Record Holder |
6900 and 7100
538 gear and 28x9 hoosier. I run a 26x9 for the 1/8 and is faster than the 28's in the 1/8 test and tune here Thursday and will try jets Think i will get me some extra $$$$$ and call Deano Thanks again
Liked 15 Times in 2 Posts
I'll vote for O2. A LM-1 only costs $269. I have done rental/loaner LM-1's with racers that goes like this. You get the LM-1 with two bungs and plugs and I charge your card $269 + shipping. You return it within 3 weeks (without the bungs & plugs cause they are welded on you headers) and you get a refund for $234 if it's not damaged (so it cost you $35). Keep it longer or damage it and I just send it back to you.
Dean Oliver got his O2 & logger from me. |
Liked 3 Times in 1 Post
Danny, call me at 573-651-3158 and I'll try to help. As Deano says, the law of physics arent any different under my hood than yours. (Even though I argued with him for better part of a year!)
AND, if you havent had your carb back to Dean in the last 6 months to a year, you're missing quit a bit of 60' and et. Get your carb updated, you wont be sorry...... Wade O |
