Old 03-28-2011, 07:46 PM   #1
5798camaro
Default Gapless top rings
I'm tring to decide between going with gapless top rings or the more conventional route. I saw about a year and a half ago there was a tread but no engines had come back to be refreshed yet. So my ?'s are
1 how much H.P are they worth
2 how many of you have had issues with them
3 what is the proper break in procedure
4 how is the engine wear
I run a 87 camaro with a 305 FI
Thank you for your time.
5798camaro is offline   Reply With Quote
Old 03-28-2011, 08:15 PM   #2
Default Re: Gapless top rings
What you need to do is talk to Keith Jones at Total Seal. He'll tell you straight up what you need to know.
I do not run them, I run various Total Seal Advantage sets as well as Diamond or Gold profile ring sets.
The gap less top ring may work okay, I'd stay far away from gap less second rings.
Rings packages make power. However, trick rings are not a substitute for perfection in bore preparation. It doesn't not matter how much your rings cost, or how trick they are, if your cylinders are not perfectly straight and round, with the correct finish, nothing will work. The flip side of that is that if your bores are as close to perfect as possible, a lot of dynos will be hard pressed to repeatably measure the difference between a killer ring package and a good package.
Old 03-28-2011, 08:40 PM   #3
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
just came off the dyno with a fresh motor ,new springs,rings,bearings,3/8 push rods every thing was the same from last year ,i went with the gapless top ring pack and a naiper second ring with good results ,,just follow the instructions,dont make the top ring gaps tight,call total seal for options and they will work,and they where not priced to bad ,they are worth some hp at least in my application
gmonde
Old 03-28-2011, 08:50 PM   #4
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: Gapless top rings
gmonde
Garrett,we need all the HP we can get.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-28-2011, 09:31 PM   #5
gmonde
gmonde's Avatar
ed the place where i dyno my motor made me wash the dyno room down after we where done ,,he didnt want any amc contamination on his chevy stuff ,talk about not feeling the love gmonde
Old 03-28-2011, 09:35 PM   #6
K Stubbs
Liked 20 Times in 3 Posts
I do not run them.....Yet, but I do know some of the 305 combos are running them and having very good luck.
K Stubbs is offline   Reply With Quote
Old 03-29-2011, 09:09 AM   #7
Tim Lisson
"just came off the dyno with a fresh motor ,new springs,rings,bearings,3/8 push rods every thing was the same from last year ,i went with the gapless top ring pack and a naiper second ring with good results ,,just follow the instructions,dont make the top ring gaps tight,call total seal for options and they will work,and they where not priced to bad ,they are worth some hp at least in my application"
gmonde
gmonde, did you use a thin napier second with spacer or 5/64 napier?
Tim
Tim Lisson is offline   Reply With Quote
Old 03-29-2011, 09:19 AM   #8
ron mattson
Liked 69 Times in 32 Posts
How much oil ring tension are you running with these? also how did they tell you to hone the
block? i have talked to total seal a few times and get a different answer every time.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 03-29-2011, 10:13 AM   #9
Ed Wright
Ed Wright's Avatar
Ron, try to talk to Keith. He wrote me an almost full page of instructions at SEMA last year. Very helpful guy.
Ed Wright 4156 SS/JA
Old 03-29-2011, 06:24 PM   #10
gmonde
gmonde's Avatar
gmonde
Tim
i just stuck with the one napier ring 5/64 gmonde
