Old 03-21-2011, 04:15 PM   #1
John Lang
Liked 6 Times in 2 Posts
Cool Torque Spec's Trailer
I've got 1/2"x20 wheel studs, 8 per wheel, what should the torque be on the wheels? I always put them at 65#, and today a trailer place said they should be tighened to100#? I think that would stretch the stud ? Thanks........John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 03-21-2011, 05:06 PM   #2
magnumv8
Default Re: Torque Spec's Trailer
1/2-20 should be torqued to 100 lbs......
D L Rambo.....
magnumv8 is offline   Reply With Quote
Old 03-21-2011, 06:07 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Talking Re: Torque Spec's Trailer
I have been told 90-100lbs. Jim
Old 03-21-2011, 07:42 PM   #4
henrys57wagon
henrys57wagon's Avatar
My trailer spec's are 90- 100
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 03-21-2011, 09:11 PM   #5
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
The sticker on the side of my trailer, with 1/2-20 studs, says to tighten to 110-120 lb-ft.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-23-2011, 02:13 PM   #6
John Lang
Thank all of you for answering my question ! Once again, I was wrong ! Does it make a differance if your using Aluminum wheels ? Thanks........John
Old 03-23-2011, 10:38 PM   #7
magnumv8
John....with aluminum wheels it is VERY important to recheck the torque of the lugnuts more often than with steel wheels.....since trailer wheels have a lot of side loading from turning the aluminum will compress and deform as the lugs loosen up,most will eventually take a set and stay torqued, but, I have always checked mine before every trip.....
D L Rambo.....
