Old 01-16-2011, 12:24 PM   #1
Chad Rhodes
Default How much gear lube do you run
12 bolt, spool, 4.88, stocker of course. I have run 16oz, but it kinda scared me.
Chad Rhodes 2113 I/SA
Old 01-16-2011, 12:53 PM   #2
Liked 1,788 Times in 408 Posts
Default Re: How much gear lube do you run
A pint and a half over full. Synthetic.
Old 01-16-2011, 02:38 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Chad,
With several different 12 bolt combinations I run 1.5 quarts of conventional 80/90 GL5 gear oil. [usually Shell or Valvoline]
After 100's of runs, all looks fine.
Larry Woodfin 471W
Old 01-16-2011, 04:51 PM   #4
rowdyboys31
Chad, I have ran 1qt of gear lube in both 10-bolt and 12 bolt rearends for 30 years! I have never had a R&P or bearing burn up, I feel in a 1/4 mile run there is not enough heat builtup and maybe you'll gain some hp? I have run 1qt of Mobil 1 Synthetic gear lube for the last 10+ years in my 455 G/SA Buick. If you are having trouble with R&P I would guess improper setup is the cause or you have a STICK. JKeihn 3954
rowdyboys31 is offline   Reply With Quote
Old 01-16-2011, 06:44 PM   #5
Chad Rhodes
no problems, just about to change gears and was thinking about it.
