Guest
Posts: n/a
12
Liked 56 Times in 29 Posts
If your year had F35 HD frame available as an option, it is the convertible frame, adds about 40 lb but will give you a tremendous increase in stiffness.
Guest
Posts: n/a
secret :0
Liked 336 Times in 183 Posts
Any GM midsize convertible frame (buick/cutlass/lemans/gto) of the same years had boxed frames extra support in the rear kick up area etc.---all the others were C frames the Conv also had more body fastening points for frame to body stiffining
Guest
Posts: n/a
secret :0
Liked 727 Times in 221 Posts
The El Camino and the wagon use the same wheelbase frame,but the wagon is a C cross section.I seem to remember some El Caminos have a boxed frame.The 4 door, the wagon,and the EC are a longer wheelbase than the 2 dr.hardtop and the convertible.There's just enough differences to really screw you up if you don't catch them!The 68-72 2 dr hardtop all use the same frame, so there are 5 years of similarities here.
Guest
Posts: n/a
Greg, thank you...
Jason |
Camino has the boxed frame ---WAGONS DO NOT they have the C frame
Guest
Posts: n/a
secret :0
2011 NHRA rulebook section 10A page 8 says frame must be stock for body used so I'll check to see if GM had a HD frame for the 2 door HT yers is a HT correct???
