Old 11-30-2010, 02:48 PM   #1
FED 387
Liked 332 Times in 180 Posts
Default identifying planetary ratios???
need some help here--Came across a few PG planetaries some long and some shorties----As far as the shorties go is there a sure fire way of identifing the gear ratio if it is not stamped on the end of the shaft??? like counting teeth or some other way???? how many teeth on a gear is there for a given ratio??? when they rework a planetary to change the gear ratios which/what gears are they actually changing??? FED 387
Old 11-30-2010, 08:31 PM   #2
G Anderson
Liked 4 Times in 3 Posts
Default Re: identifying planetary ratios???
TCI had a copy of this on there web site that told the process of how to count the teeth to determine the ratio I got this off there about 5 years ago, if they no longer have it contact me and I will e-mail acopy to you. GA
G Anderson is offline   Reply With Quote
Old 11-30-2010, 08:48 PM   #3
FED 387
GA thanx I think I found the article you are referring to--If it is not the correct document I will get back to you---Again thanx for your reply ---Comp
