Hey folks,now that I've made and installed lexan windows in my Vega,what is the best way to clean and protect them? I've heard a lot of things,formula 409,Palmolive and water,but what do you guys use? Thanks-Lew.
Tranquility base,the Vega has landed... |
Liked 2 Times in 1 Post
I use Plexus for routine cleaning. Jerry Bickel sells it but I have seen it in local hardware stores. Try those that sell plexiglass/lexan.
Ditto!!
Scott fifield |
Liked 138 Times in 51 Posts
A spray on plastic polish called 210 (or something like that) works well. Isoprophyl rubbing alcohol also seems to clean it and does a good job of removing shoe polish from the windows. It literally melts it and reduces the amount of rubbing required to get it off.
Cool,thanks peoples,believe it or not,Amazon.com sells Plexus,and there's one of their locations about 5 miles from me.
Liked 642 Times in 192 Posts
Plexus is good and look at Novus had some good success with that as well
Liked 91 Times in 51 Posts
You should be able to get Plexus at your local motorcycle dealerships.
CD |
Jerry Bickel & Quarter Max sells the Plexus
Joy dishwashing det. and a soft cloth. Remember nothing that contains alcohol.
Kevin |
