Old 11-11-2010, 09:42 PM   #1
Jim Davis
Question Hood Pins
Hi All;
Are hood pins legal in NHRA Super Stock
Jim Davis 2448 SS
Jim Davis is offline   Reply With Quote
Old 11-12-2010, 09:25 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Hood Pins
Yes, but if your car did not come with a lift off hood, you must still have the hood attached to the hinges , and have the factory hood latch .
Old 11-12-2010, 10:34 AM   #3
mannymen
Liked 13 Times in 7 Posts
I have the pins with a cables on mine, but I'm switching to these this winter.
http://www.steeda.com/store/steeda-s...d-mustang.html
N/A
mannymen is offline   Reply With Quote
Old 11-13-2010, 10:31 AM   #4
Mike Graham
Liked 341 Times in 67 Posts
Tom
Is that in print anywhere? I was told no hood pins in 09 after an incident with a broken hood latch that nearly destroyed my car. I sure would like to add them
Mike Graham is offline   Reply With Quote
Old 11-13-2010, 11:08 AM   #5
Jeff Lee
Jeff Lee's Avatar
I think Tom is saying you can'y use hood pins as an excuse to remove weight from the front of the car. I can't see any reason not to have hood pins if that is your choice but they would be there along with the rest of the hardware as factory equipped,. And of course some cars are factory equipped with hood pins, latches and hinges (like '70 Mustang & Shelby for example)
Jeff Lee 7494 D/S '70 AMX
Old 11-13-2010, 11:11 PM   #6
mannymen
I added the pins for JIC. You never know when air will get under the hood somehow separating it from the latch.
N/A
Old 11-14-2010, 02:39 AM   #7
Tom Goldman
not specifically in the rule book to my knowledge.
I was told by the Tech dept many years ago it was ok as long as the stock latch and hinges were retained .
it can only be considered a safety improvement, especially at the speeds we're seeing in S/SS.
A lot of the cars from the late 60's and early70's [like my and Jeffs AMX's] have so much hood in front of what is a realy wimpy latch, it just makes sense to use them .
