Old 06-30-2009, 07:23 PM   #1
j gardiner
Liked 55 Times in 29 Posts
Default vp racing fuel
A little while back i posted a question about vp110 and if it was the same as the stock/super stock fuel listed in the accepted fuels list. I found out from vp it is indeed the same fuel just made in different places. They are changing the name of the stock/super stock fuel to sportsman. If you buy it at your local track it will probably be called vp110 and if you buy it off the truck at a race it will be called sportsman.
j gardiner is offline   Reply With Quote
Old 07-01-2009, 10:03 AM   #2
John Mason
Talking Re: vp racing fuel
I would research this a little more. I can buy VP 110 for less than $7/gallon compared to almost $11 for C-12. I doubt a fuel that cheap (?) will be NHRA accepted.
John Mason 7743 SS
John Mason is offline   Reply With Quote
Old 07-01-2009, 11:07 AM   #3
j gardiner
Default Re: vp racing fuel
I did research it. I talked to one of the main guys with vp on the phone about a month and a half ago. He was also at the richmond sportsman national. They also just came out with a press release. That was the whole point was to have a fuel that was more affordable. I running it all year and I get the same performance as I did with torco or sunoco.
Old 07-01-2009, 12:31 PM   #4
Rory McNeil
About 5 years ago,I tried running the VP 110 , which was also called "Motorsport Red" at the time, as my 8.4.1 compreession 302 certainly doesn`t need the pricy stuff. It ran fine, but out of 3 different attempts, from 2 different drums, it failed fuel check at a LODRS race twice. I was told it was not as stable as V12, so I switched to V12, and have never flunked a fuel check since.
NHRA 6390 STK
M/S 85 Mustang
Old 07-01-2009, 12:37 PM   #5
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Sunoco Blue is just as fast and a ton cheaper.
Old 07-01-2009, 04:37 PM   #6
j gardiner
He did tell me that the vp 110 should pass but to check it first to make sure. It is made in various places throughout the country. The stuff they bring in on the truck is made in san antonio and it is made with tighter tolerances.
Old 07-01-2009, 05:32 PM   #7
John Mason
The VP 110 isn't on the NHRA accepted fuels list. VP shows it as being purple and the list shows the Stock/Superstock fuel you referred to as light blue. There's also nothing called "Sportsman" on the list, but it hasn't been updated since May 2007.
I'd check this out before running it.
John Mason 7743 SS
Old 07-02-2009, 03:15 AM   #8
art leong
I got tossed a couple of years ago with VP110. It is not on nhra's approved list
Art Leong 2095 SS
Old 07-02-2009, 08:28 PM   #9
MontyC
The VP guy at richmond said you have to ask for the Sportsman fuel. I'm pretty sure he said the "110" is different. The Sportsman fuel is light blue.
MontyC is offline   Reply With Quote
Old 09-23-2009, 12:19 AM   #10
Jimi B
Sorry to thread dig, but I am a newb to class racing... I just want to be clear on something. I had just taken it for granted that if you wanted to run a lesser fuel.. Say pump gas , that this would be ok. From this I am gathering that is incorrect. You absolutely have to run accepted fuels? If the fuel you wanted to run would be a lower octane, lower specific energy etc, this is not acceptable?
Jimi B is offline   Reply With Quote
