Old 05-31-2010, 04:26 AM   #1
J Halsey Jr
Default radial tires.
Do's any one how much faster or slower a 9/30 radial slick is over a bias 9/30. Thanks
J Halsey Jr is offline   Reply With Quote
Old 05-31-2010, 05:37 AM   #2
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default Re: radial tires.
Mickey Thompson 30x9 radial is .13 faster in the 1/4, about .08 faster in the 1/8th than a comparable bias ply.
Old 06-03-2010, 07:52 PM   #3
HawkBrosMav
Liked 302 Times in 73 Posts
Does anyone know if a 30x9 radial will fit on an 89' mustang without having to modify the wheel openings? We have a bias goodyear slick 28x9 and it fits no problems. It grows and the radials will grow less so we are thinking it might work. anyone try it before?
another question does anyone make a radial that is 29x9? I guess I haven't done enough research.
BH
Old 06-03-2010, 08:42 PM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
M/T makes a 29.5X9
Old 06-03-2010, 09:44 PM   #5
72Malibu
72Malibu's Avatar
Hoosier makes two versions of their 30x9 radial slick, one with 92.5 rollout and one with 94" rollout.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 06-03-2010, 09:51 PM   #6
67ss
Bob, how close are the 94" roll out tires to the front of the 1/4 lip on your car? I run the 92.5" roll out and have about 7/8" of clearance so the taller tire would be a tad over .5". Since these things don't grow at all I figure that should be plenty. Gettin ready to buy new tires and was thinking of going to the taller one.
Chad Harris
67 Chevelle SS
http://mysite.verizon.net/harrisracing
67ss is offline   Reply With Quote
Old 06-03-2010, 10:43 PM   #7
Rory McNeil
Liked 1,104 Times in 302 Posts
[QUOTE=HawkBrosMav;190465]Does anyone know if a 30x9 radial will fit on an 89' mustang without having to modify the wheel openings? We have a bias goodyear slick 28x9 and it fits no problems. It grows and the radials will grow less so we are thinking it might work. anyone try it before?
Unless a 89 Mustang has a considerably larger wheel well opening than my 85, I doubt that a 9x30 would fit without some trimming. I used to have 9x28`s on 8" wide Weld Draglites with 5 1/2" back space, which required some good hammer blows on the inside, but nothing on the actual openings, but when I switched to M/T 9x29 1`2" slicks, I had to do quite a bit of slicing & hammering on the wheel openings, especially in the front sections.
NHRA 6390 STK
M/S 85 Mustang
Old 06-03-2010, 11:45 PM   #8
HawkBrosMav
Rory,
when you switched to the larger tire was it to a radial or still a bais slick? I guess what i'm really asking is did you have to trim to get the tire just to fit in general or did you have to trim it to give the tire room to grow?
Also to anyone,
How much clearance would I need to make sure I had with a radial? I understand they don't grow much if any at all... would 1/4" be enough??
BH
Old 06-04-2010, 04:54 AM   #9
Chris1529
Liked 70 Times in 29 Posts
I think you would have to trim the wheel openings. I know they would'nt fit on my 84, so if you have an LX Mustang, I think the openings are the same. If you have a GT, the ground effects probably make them even smaller.
1/4" is cutting it pretty close. You would have to check the tire for clearance around the entire tire plus account for any shifting of the body. In my opinion, 1/4" is probably a little close.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 06-04-2010, 07:36 AM   #10
72Malibu
72Malibu's Avatar
I've got at least an inch at the front of the wheel opening. I tried Garrets 92.5's at the end of last year and they looked kinda small
*** 72 Malibu ***
