Old 05-28-2010, 04:40 PM   #1
chevy 68
chevy 68's Avatar
Default Engine Breaks Up on Converter Flash
I have a problem with my 1968 Chevy Camaro, the engine (502 Chevy BB) breaks up on converter flash. The third gear converter used to flash at 4200 RPM, now it flashes at 3200-3600 RPM and the engine skips. Also, the cars ET has dropped 3/10ths of a second. Any help with this problem will be greatly appreciated! Thanks!!
chevy 68 is offline   Reply With Quote
Old 05-29-2010, 10:49 AM   #2
Dick Butler
Liked 32 Times in 19 Posts
Default Re: Engine Breaks Up on Converter Flash
If you are meaning that it pops on mashing the accelerator from idle to flash, check ignition pickup. One of my moroso type developed this problem. Check Gap also and Coil would be next or box....
Now there is also a possible Convertor problem which should be considered with the severe drop in flash...
Old 05-29-2010, 12:06 PM   #3
Liked 5,153 Times in 1,967 Posts
Breaks down under load?
How old are the spark plug wires?
Old 05-29-2010, 04:06 PM   #4
chevy 68
chevy 68's Avatar
Mark, I ohm tested the wires, and they checked out okay. But they are two seasons old. Could the ohms be okay but the wires still be bad? Thanks for your reply!!
Old 05-29-2010, 04:11 PM   #5
chevy 68
chevy 68's Avatar
Dick, Its a factory HEI and it has worked well for 3 years. Thanks for your reply!
Old 05-29-2010, 04:58 PM   #6
Chris Hardy
Guest
Posts: n/a
You haven't changed the timing recently???
I had nearly this same issue several years ago. Start up the engine in the dark and look for wire arcing. If you see nothing, check all of your valve springs and do a compression check. A broken valve spring does funny things.
Best regards,
Chris Hardy
