Old 05-07-2010, 04:14 PM   #1
7423
Default 5.0 Ford at .060 over bore??
Question for the blue oval gang. Is it advisable to fill a 5.0 roller block for cylinder stability at .060 over? Gathering info and parts for a fresh bullet.
Thanks in advance.
7423 is offline   Reply With Quote
Old 05-07-2010, 05:58 PM   #2
rawhide
Liked 7 Times in 5 Posts
Default Re: 5.0 Ford at .060 over bore??
Charlie,
I would recommend filling the block. The last one I bored .060" only had about .075" of cylinder wall left. This is easy to measure after you drop a valve.
thanks, Roland
rawhide is offline   Reply With Quote
Old 05-08-2010, 12:08 AM   #3
Rory McNeil
Charlie, my machinest says the 5.0 Ford blocks are fairly weak in the cylinder wall department, so he even Hard Blocked my engine, even at only .030".
NHRA 6390 STK
M/S 85 Mustang
Old 05-08-2010, 08:38 AM   #4
BlueOval Ralph
Banned
The org. Boss 302 blocks will go .060 or if you are brave .080 over ask Fadely or Mike Edwards
BlueOval Ralph is offline   Reply With Quote
Old 05-12-2010, 12:43 AM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: 5.0 Ford at .060 over bore??
I fill everything .030 & up. even if you do a "short fill" that will help.
Old 05-12-2010, 04:32 PM   #6
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Smile Re: 5.0 Ford at .060 over bore??
Buy the sportsman or svo block, you'll be much happier in the end.
Old 05-12-2010, 06:01 PM   #7
rawhide
Ford Racing has discontinued the Sportsman block and the part number for the SVO block is now M-6010-BOSS302 or M-6010-B302BB.
Old 05-13-2010, 01:49 PM   #8
Chris1529
Liked 70 Times in 29 Posts
Does that BOSS block accept stock style heads(windsor, gt40, etc.), or does it take a Cleveland Style head?
I wouldn't worry about a stock block at 30 over. I've heard when you start getting over 7000 rpm is where you have trouble, and the block will split. -nothing related to the overbores.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 05-13-2010, 02:09 PM   #9
SSDiv6
It accepts Windsor style heads.
