Old 04-27-2010, 11:52 PM   #1
bdixon
Liked 15 Times in 7 Posts
Default front end wobble???
Hi we were out testing tonight, a 1972 a body duster f/sa getting used to car,, in high gear after getting out of gas we are getting a pretty severe tire wobble, not during braking but out of throttle,, front end has just been aligned, steering feels tight , tire pressures are good anyone with any good ideas?? thanks in advance,, bryan
bdixon is offline   Reply With Quote
Old 04-28-2010, 12:24 AM   #2
Moparteacher
Default Re: front end wobble???
Excessive positive caster will cause a high speed shimmy. Suspension is going into jounce upon decel thus moving the lower ball joint up and the upper ball joint up and back increasing positive caster.
A decrease in the positive caster setting, or a steering dampner should resolve the issue. A stiffer shock setting that prevents nose dive may help also, but I recommend a caster setting change.
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
Old 04-28-2010, 12:34 AM   #3
bdixon
Smile Re: front end wobble???
Thanks for the info Gary will check it out,........bryan
Old 05-01-2010, 10:26 PM   #4
GTX JOHN
Liked 2,493 Times in 700 Posts
Last time I had that problem on my Demon.......lower control arm bushings were really egg shaped from coming down hard on front wheels. You may be able to see them (arms) rubbing on K .member. Jack it up and check for looseness. While you are under there look at strut rod bushings too. Both common problems on Mopars. Call me if you need to know more.
PS got all your stuff gathered up
John Irving
GTX JOHN is online now   Reply With Quote
Old 05-02-2010, 12:15 AM   #5
bdixon
How ya been? Going testing sunday with 72 340 a body, will drive this till mine is done.. found our wobble was bad drag link,
Old 05-02-2010, 12:16 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
You might also check all the connection points on the drag link for wear or being loose...
Adger Smith (Former SS)
Old 05-02-2010, 12:29 AM   #7
bdixon
thanks that was our problem got it fixed today thanks again bdixon
