Old 01-25-2010, 11:49 AM   #1
Bill Pomponi
Default B&M Pro Ratchet shifter - T-350
Friend is installing a new B&M Pro Ratchet shifter utilizing a Turbo-350, and having trouble with the adjustment and almost seems that the geometry is not right. He has checked the brackets etc all look OK.
Any Ideas?
Bill Pomponi is offline   Reply With Quote
Old 01-25-2010, 07:54 PM   #2
Footbrake
Footbrake's Avatar
Default Re: B&M Pro Ratchet shifter - T-350
Assuming that he has the correct trans shift lever on and the cable is in the middle hole of the bracket, Tell him to adjust it so that both shifter and trans are fully in first gear.
Footbrake is offline   Reply With Quote
Old 01-25-2010, 10:25 PM   #3
1299
Liked 54 Times in 12 Posts
is he having a problem geting in to park? if so to get in to park he need to hit the shifter 2 time. that is normal op.
1299 is online now   Reply With Quote
Old 01-26-2010, 09:54 AM   #4
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
I have had 2. Last one, was adjusted way too many times, and always had to hit it twice, to go into park and twice to go from park to reverse. Changed to a PPP, and no more problems.
2894 STK
Old 01-26-2010, 11:02 AM   #5
Bill Pomponi
Thanks for your honesty and sincerity.
Glad I don't use one !!
Old 01-26-2010, 06:24 PM   #6
race watcher
It is in the instruction manual. You must double shift to go into park from reverse and the same to get into reverse from park. For T 350 only.
race watcher is offline   Reply With Quote
Old 01-27-2010, 04:45 PM   #7
bobby
bobby's Avatar
Same for a TH400. I have had one since 85 and love the thing. I wouldn't use anything else. One thing I did have to do is build a new lever for the tranny. The cable mounting hole was off by about 1/2 a hole. The lever needs to be the same length as the shifter arm. Hole to hole. Does this make any sense? My lever was shorter and you could either get into first or park, but not both, depending on the adjustment.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 01-27-2010, 08:09 PM   #8
Bob Shaw
Liked 317 Times in 62 Posts
I have used that shifter on my last 4 cars and love them, but I always had to modify the lever on the trans to get the geometry right. B& M says that it is not a problem!
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 01-27-2010, 08:12 PM   #9
Kenny Wigington
"It is in the instruction manual. You must double shift to go into park from reverse and the same to get into reverse from park. For T 350 only."
I got both second hand, last still was in the box, but missing the paperwork, if I remember it correctly. First was in a car I bought. Both seemed to work without any major worries, other than the double hit biz. I had it on a 904, in the first one, and in my stocker I have now, at first, connected to a T-350 initially, and later to a Metric 200. They're not bad shifters, Im just more comfortable with the PPP.
2894 STK
