Old 12-22-2009, 08:21 PM   #1
rseibenick
Liked 20 Times in 7 Posts
Default GM valve spring # 10212811
Need infomation on GM valve spring # 10212811 . Wanting to know installed height and lbs. and open height and lbs. Also coil bind . Any ideas , on how to obtain this infomation. Thanks
rseibenick is offline   Reply With Quote
Old 12-22-2009, 08:36 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: GM valve spring # 10212811
"Part # 10212811
Spring Type: Single spring. Outside diameter: 1.25". Pressure @ installed height: 80# @ 1.70". Solid height: 1.20". Average Rate (lbs@in): 256. Retainer P/N: 10241744. Valve Seal Kit P/N: N/A. CT350/350, 350HO engines"
Not much of a spring for anything more than a street car from the specs shown. A performance type stock spring like the old Z/28 type had about 105lbs on the seat.....80 is very close to stock non performance stuff.
Rich Biebel
S/C 1479
Stock 147R
Old 12-23-2009, 07:33 PM   #3
rseibenick
Thanks for the info.
