Old 12-12-2009, 02:38 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 3rd generation Camaro/Firebird headers by Hedman
Hedman builds a 3rd generation 1 3/4 x 1 7/8 header that has the tubes exit into a "flat" collector. That is to say, all tubes are side by side, horizontal as they enter the collector. Thus, giving excellent ground clearance.
The design looks good and I think it will fit my combination well.
But before placing the order, do some of you know racers running this header?
Larry Woodfin 471W
Old 12-12-2009, 05:09 PM   #2
Lee Valentine
Liked 319 Times in 68 Posts
Thumbs up Re: 3rd generation Camaro/Firebird headers by Hedman
Larry, My son Bryan had a set of them on his 85 camaro stocker and think they were faster than any thing he has tried since. I am putting a set back on next year!
Lee Valentine 1661 STK
Old 12-12-2009, 05:47 PM   #3
Dragsinger
Default Re: 3rd generation Camaro/Firebird headers by Hedman
Thanks Lee,
I appreciate the note.
Larry Woodfin 471W
Old 12-12-2009, 07:02 PM   #4
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Jorge Carnero, Hugh Meeks come to mind right now. I know they are both happy with them . Note- I think you will have to use a shorter oil filter, but it should clear without using an adapter.
2894 STK
Old 12-13-2009, 01:29 PM   #5
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
oil filter will not be a problem with the hedmans , but after running them on two different third gen stockers the ones i had built by pete z. were better quality,fit better and were faster in my opinion than the hedmans
jim powers is offline   Reply With Quote
Old 12-15-2009, 01:33 PM   #6
STOCK1278
STOCK1278's Avatar
There will be ground clearance problems with that header. They also make a special order three step that is better than that. For the money call up Pete Z and order a set of his with a merge megaphone collector... KO
Jason M Silver
NHRA Stock Eliminator - 1278
88 Oldsmobile Cutlass 307/213
STOCK1278 is offline   Reply With Quote
