Old 11-23-2009, 09:25 AM   #1
njk53
Default Rubber Spring Cushions
My brother and I are doing some rear end maintainance work on our car, which is a Chevrolet Wagon. The rubber cushion/dampner on the top of the coil spring that interfaces with the frame on the one side was torn up pretty bad. I was wondering should I replace the cushion or leave it out completely? Opinions?
Nelson Kowal
Stock 345
Old 11-23-2009, 01:31 PM   #2
tj310
Default Re: Rubber Spring Cushions
Slip a piece of heater hose onto the top coil.
Old 11-24-2009, 03:22 PM   #3
67ss
You can leave it out. Don't have them in our car. If it were a street car you would want to keep them in to quite the ride a bit I guess but otherwise just leave them out. Energy Suspension sells poly ones to replace them if you want.
Chad Harris
67 Chevelle SS
http://mysite.verizon.net/harrisracing
67ss is offline   Reply With Quote
